Force feedback woes
chunksin
21 (100%)
733CR
Hi all,
I think the servo drive board on my Initial D 2 cab has developed a fault, I was playing last night and the resistance suddenly gave way and the wheel spun freely. I restarted the game, got an error 22 which I think is complaining about the netdimm (?), restarted it again and the game started normally. There was no pop, no magic smoke it just suddenly stopped.
The board has a constant flashing red LED which it normally has when a non FFB game is running and the kickback test when the game boots still does something, the wheel kicks as normal then it looks like its trying to centre the wheel a couple of times then throws it all the way to the left. The red LED continues flashing as the game runs and there is no FFB in the game.
Has anyone seen that before? any idea if its my board or my FFB motor?
Any help gratefully received!
cheers,
Rich
chunksin
21 (100%)
733CR
Yep, and they aren't cheap
Outrun2
Colonel Outrun
1,182CR
Very, very unlikely it's the motor at fault - they go on forever.
More often than not ffb problems are caused by wiring issues in my experience. It sounds boring and not very techy but check pins on all cables going to/from motor and drive board, particularly behind dash as things can get snagged or pulled out very easily back there!
Also does the game play normally without ffb? Does the steering pot register smoothly in test mode?
Does the ffb test in Club Kart report the same errors?
Outrun2
Colonel Outrun
1,182CR
It's all too easy to fear the worst, so a great relief when it is something simple.. and cheap to fix!
Glad you got it sorted, had the dash off one of my cabs today - those looms are so easy to snag or get trapped, it's always worth double-checking everything is secure before firing up!
