Fried Pcb..
charlesapex
21CR
Link sent via Pm with link to YouTube vid
Martinmurphy30
421CR
Hi Charlie, if you can test all the kick harness wires until you find player 1 shot 1, connect that wire to pin 1 of the DB9, then test and connect shot 2 to DB9 pin 2, and finally shot 3 to pin 3, then test the inputs using the player one controller, think it should be blue button, l shoulder and r shoulder for 4,5,6. Let me know how that goes, I have 1 more test in mind. Good luck! Lol!
charlesapex
21CR
Thanks for your help mate, I'll give it a try tomorrow. Just to confirm, do all the wires need to be connected on order for this to work properly? I wasn't sure if it's because I was trying them one by one. I will follow your advice and see how it goes...
Martinmurphy30
421CR
I'm honestly not sure, it depends how the Arduino code is set up on the adaptor you have. But if you can work out which wires are player 1 shots 4,5+6 and connect those to the DB9 pins 1,2+3 then that will be all player 1 connected and should hopefully work.
charlesapex
21CR
Martin,
Thanks for your help, I wired them all in and low and behold - it worked... For anyone reading this at some point that was havinhf a similar problem, they all have to be plugged in to the kick harness for it to work properly.
That's the good news, bad news is there was gfx glitching and after carefully reseting the roms, it no longer boots. I'm not that bothered, I have another board that I'm repairing which is in much better condition.
The other sf2 CE board I have was one I connected the jamma edge connector to upside down, it fried a chip and a trace appears burnt. I replaced the chip with a new replacement and the game boots up fine when no controller is plugged into port 1 - when I plug it in, the screen goes slightly fuzzy and game intermittently restarts. I'm guessing it's the trace that's fried which is causing the problem. Last question is this: can I simply solder a jumper cable from jamma edge connector the solder point of where the tracing ends? I'm guessing the board should be OK if I bypass this burnt trace.
Thanks for all your help with this so far, hopefully I'll be enjoying a game of sf2 with no glitches and kick buttons this evening!
Martinmurphy30
421CR
Great news! Also check switch j1 on your supergun is turned off, it changes between jamma and chamma pinout, you want jamma/mvs setting..switch off. I'd try booting the glitchy PCB with this turned off to see if it changes anything.
And yes a jumper wire in place of the burnt trace will be fine.
charlesapex
21CR
Cheers mate,
I tried this but made no difference, I have left that button on traditional 6 button, not chamma.
I will have a fiddle now soldering a jumper cable across burnt tracking, but at least the kick harness is now working. Thanks for all your help.charlesapex2020-11-11 17:50:56
