Fuse advice
2,265CR
I need to replace the fuses in my Circus Charlie for the voltage change. Not entirely sure which is the UK equivalent type or where to get them. From what I can see 3AG means 32mm slow blow. But want to be sure.
GameOn
133CR
The 3AG is just the size 1.25 inch long by 0.25 inch thick (or 6.3mm by 32mm), its a 250V and 1.5 Amp fuse, although if its the psu then you probably want a slow blow.
1 and 2 amp fuses are easy to find, 1.5A might be a bit tricky.
simonden
20 (100%)
1,042CR
?? Seriously?
I have no issue finding 1.5A slow blow/time delay 250v fuses:
Here is the list from RS (all SlowBlow/timedelay, 1.5A, 250v)
412-504
611-0254
541-3013
866-8216
849-5462
852-7118
849-5245
878-3517 (these are specifically marked as 3AG)
852-7039
854-9196
854-9285
Here is the list from Farnell (again, all SlowBlow, 1.5A, 250v)
540055
1596742
1596873
1596829
1615123
1150665
1150684
1149859
1651757
simonden
20 (100%)
1,042CR
As GameOn says, 3AG is just a reference to the size, not to whether it is a Time Delay fuse (which would have a 'T' at thend of the specification.
Personally, I would never use a SlowBlow fuse unless the manual or specs state it. (changing a fuse that blows to quick is easy, fixing the consequences of a fuse that blows to slowly is not as easy).
bomjac
453CR
Change only the fuse Olly - leave the wire link in. The 220v side is fused for 2 fuses on the assumption that it is a US style 220V supply.
US supply is 120V L-N, 220V L-L. UK supply is 220v L-N. Connect the UK live to the fuse and Neutral to the wire link.
@Simon - Transformers should always have a slow blow fitted, as the inrush current can be as much as 20* the rated amps.bomjac2015-10-05 11:03:42
joe34
448CR
hey muddy fyi farnell still have their free delivery for any order eg. even if you order one single component.
if you order by 8pm it will arrive the following day.
