Galaxian PCB
jonhughes
1,160CR
I probably need a Galaxian expert for this problem. Picked up a Galaxian PCB for repair which was dead and managed to get the PCB booting. However, now that it is booting there are issues. No high score or player 1 / 2 text at the top of the screen, colours are wrong, no stars and the sprites are just one colour (also wrong colour). Sound and controls are fine. This board could have been worked on before, I suspect.
Here is what it is doing on the demo screen
After probing the sprite section, I noticed something odd happens when I short pins 5 & 6 of 74ls00 at 2P. The colours return to normal, the stars switch on and the high score and player text returns but the sprites are almost off in formation and disappear when diving (no reds, purples or blues on the Galaxians). Ship is half drawn.
If I now short pins 1& 2 of the 74ls00 at 2P the formation sprites are ok but shakey and the stars disappear. The diving Galaxians go back to being a single colour but the ship is ok.
It's showing there's very little wrong with RAMs and colours - could this be a broken line / trace or a logic problem?
jonhughes2017-07-19 15:10:15
david_orton_2000
Green Mario
344CR
Could be broken/damaged trace, even a deep scratch is enough.
My eyes are crap thesedays, so get out the magnifying glass. :)
Have you tried piggy backing another 74LS00?
-sounds like its not that far off being fixed. :)
'Macro' (Mikes Coates) is the authority on Galaxian - so try pinging him a PM.
jonhughes
1,160CR
Oh.....just not quite there 98% done. The yellow Galaxian is shaky whilst in formation but is absolutely fine whist diving - suspecting a single pin in one of the ROM sockets may be causing this - at least I have everything else now.
jonhughes
1,160CR
Ok, so I have this particularly annoying fault with yellow Galaxian when it is in formation. The bottom half of the sprite jumps to the right (copies image say 3 times). As shown in the photo. When the yellow Galaxian dives from the formation the sprites are spot on.
One thing I noticed though, if the board hasn't booted for a while (when it's cool) the issue isn't there. However, leave it on for a minute and the flickering starts (heat related). So I leave the PCB for half an hour on demo and the flickering begins to creep into the red Galaxians while in formation also. There's also some weird vertical lines around the ship area (full width where it can move) particularly when it gets blown up and in some of the demo text.
So I pull out a can of dust removing spray and fire cold air at various points on the board, thinking sprite area. Nothing happens, so next try random areas. When a dollop of the spray hits chips 5A - 5C region the fault disappears.
So I'm going to just pull and replace those chips because the fault is intermittent. See what happens.
