Galaxian
grobda
1,061CR
1st a small fix;
rack noise was too fast, like an angry bee. all the 555s were ok. turned out to be a 2.2uF cap instead of a 1uF at c15, replacing fixed it.
2nd the problems;
got one PCB with a starfield thats going way too fast, any ideas what controls the speed?
another PCB that came with a 7404 at 1E rather than a 74368, putting a 368 in results in no clock. tried 3 368s and resocketed the chip to no avail. with a 7404 at 1E the game runs but with a solid magenta screen, the only things visible are the bullets. doesnt look like the 368 has anything to do with video generation(?). the colour prom is ok and the roms are ok.
Im trying to get my head round the schematics and googling repair logs but thought id post here in case anyone has experienced anything similar.
P-Man
International man of mystery
1,273CR
second pcb :
starfield is generated by counters at A1 and B1, they are clocked by the output of 6D pin1 (area A15/A16 on the midway schems)
Is your pcb an original Midway? the 7404 is to invert the outputs of the attack ram, because not all galaxians are made equal. There are about 5 different flavours of attack ram that can be used in Galaxians, but their outputs vary from tri-state to open collector and inverted. The 7404 is the right chip for that placing, your problem probably lies elsewhere, if you have a solid magenta screen then you need to get the video probe out and investigate further downthe line, do you get proper video generation from the character generator, does it all go to pot once the attack ram is in place? remove the attack ram one at a time and observe. If one of them is enabled all the time, it can fill the whole screen with colour, or if its faulty.. or if someone has put in the wrong type of ram.
My suspicion is that you're not working on a real midway pcb?
grobda
1,061CR
They're original midway pcb's - I got the 368 at that location from the board layout in the troubleshooting manual. Not tried anything further short of swapping the attack rams. Cheers for the info but I got sick of the sight of them for the time being ;) Once i regain some motivation I'll take a look at the character generation.
grobda
1,061CR
just found the culprit for the magenta screen. found the 74174 at 1u wasnt getting a clock. there was a break in the track that runs right along the back of the board. simple repair. just done it and graphics ahoy.
now i move onto
1; wonky colour prom (swap tested it)
2; no diving sprites, they appear to be squashed into a single horizontal line at the top of the screen (sure ive read about this elsewhere)
3; shoot noise is curtailed
i'll look about the net for these faults, anyone know where to get colour proms from? 82S123... not cheap offof ebay; might go for this instead; http://www.retroclinic.com/leopardcats/galprom/galprom.htm
andyman
1,059CR
1. $3 arcadechips.com
2. Diving sprites are all controlled by the attack ram, I had lines through them with the first and last removed, so start there.
3. I had problems with the shoot noise, turned out to be LS159 @ 9N
grobda
1,061CR
cheers, put an order in for the proms.
i managed to get diving objects back by replacing the 273 at 6m. i thought some of the outputs should have been pulsing and there were low, and it failed when i removed it and tested it in the vp280's ttl tester.
problem now is they dont dive properly - they flicker and jerk upwards as they dive, so they dont get further down than halfway. the bullets they shoot appear normally. theres also no explosions when you hit any galaxians.
I used the test rom on macros site and the ram all passed. i swap tested them all with the one spare chip i have and it didnt make any difference. Guess i'll try the buffers next, and the 159 for the shoot noise.
i'm enjoying working at it, it's a learning experience.. :)
grobda2012-01-27 16:35:34
grobda
1,061CR
had another board with no daughtercard and missing chips, so i repopulated it with parts from the faulty above and got bad ram 3. piggybacked a good ram on the 9101 at 4f and it worked, but with no starfield. found a hack at pin 1 of the 366 at 2b and repaired it. works! nice to get something working :)
faults seem to be either really easy or totally beyond my comprehension, my conversion rate is improving though :)
ive got a half baked idea to get two boards running simultaneously and compare them to fix the dud...
