Gallag Bootleg Clone Schematic Needed.
MrCocktail
1CR
Morning guys,
I’m looking for a schematic for a couple of green Gallag clone PCB’s I have which require some repairs, can any one point me in the right direction?
Or someone who would be willing to repair them?
Photo for reference.
iz8dw
23CR
Hi,
that's actually a "blue" gallag as the incomplete and really bad looking "green" gallag schematic is too different from those boards.
I have repaired one of those boards, as you can see in this video:
https://youtu.be/DYgBCyQSMjg
In the comment section of the video you'll find a link to my partial reverse engineering of the
schematic (cpu board only and not complete, as my board's fault was there).
Basically I've stopped reverse engineering the schematic once I could repair that board.
However, now I have a second board in the repair queue, so I might add some more parts to the schematic if the need arises.
And yes, I can repair these boards for others, but my repair queue is rather long.
I live in Italy.
Best regards
Frank IZ8DWF
iz8dw
23CR
No idea in general.
I've just looked for the various Galaga bootleg schematics, since that was what I needed to repair my board(s). However, there seem to be two gallag variants, one was called blue and the other green, probably after the soldermask color.
I assumed my board was a green variant as the soldermask was indeed green, but the partial schematic
I had found was surely not matching at all, even the chip's row and column counts were wrong and the CPUs places didn't match too.
So I assumed I had instead a "blue" boardset with green soldermask. Not that it would do any difference
actually, since both the schematics you could find about the "blue" and "green" variants were barely
legible and incomplete.
So my only option was reverse engineer the schematic and that's what I did.
As I said, my schematic capture ended as soon as I could identify the problem of my board and fix it. Capturing a schematic from an actual PCB board is a very time consuming task anyway.
HTH
Frank
