I bought a GBS-8200 from eBay. I haven't connected my game to it yet, but I would like to add some notes here for people who are considering it. Sorry if this is spelling things out for the experts but I just want to share this information.
No power supply is included and the instructions are sketchy stating a 5V-12V supply. The seller didn't know the correct voltage or polarity either.
1. I can confirm it requires a transformer with a 5V 2A positive centre. The actual current drawn is about 0.4A but that might increase if you attach a scanline generator to the VGA output.
Instead of buying a cheap power supply from eBay or Amazon I bought a 5V 3A one from CPC where it has a data sheet and the safety certificates actually mean something. It has a 2.1x5.5mm DC Plug output which fits perfectly.
Transformer:
https://cpc.farnell.com/stontronics/t6813st/ac-dc-power-supply-5v-3a-2-1mm/dp/PW04377
2. To mount the GBS-8200 on my board I have 4 Hex Spacer Standoffs M2.5x11 and 4 screw pan pozi M2.5 x 6mm.
Standoffs:
https://cpc.farnell.com/ettinger/05-12-113/hex-spacer-standoff-m2-5-11mm/dp/PC01982?ost=pc01982
Screws:
https://cpc.farnell.com/unbranded/pp2m5-6/screw-pan-pozi-m2-5-x-6mm-100pk/dp/FN02140
3. When you switch it on for the first time the menus are in Chinese. You can go down to menu option 4, press OK, and select English from there. When it is powered down it remembers the language setting.
The picture for the menus is good, steady and clear on a 21.5" UMC TV/Monitor with VGA input and good, steady and clear on a 40" Samsung. I tried it on the cheap monitor first incase there were any power issues.
I will write up my findings as I go with this.mlynn2020-06-27 01:47:46
Transformer:
Standoffs:
Screws:
