well time to put in the answer...
So first my bench setup/routine.
I have been collecting board and cabs since the dawn of time. I am 63 this year and used to frequent the arcades regularly. {I think the greatest time span to grow up.}
Started with a Space Invaders Cabinet found in the local dump sitting in the weather for 3 years. It was only a LITTLE bit water logged. But got it working again. Haven't stopped collecting, and now I have 15 cabs, 4 to still populate.
ANYWAY, I tend to find electronics in the dumpsters and salvage stuff from parts.
I even find finger boards on computer boards and cut them off to use as JAMMA Adapters.
When I am going to fix a certain board I'll make an adapter for it and then proceed to the repair.
When I decided to start to work on the Ghost & Goblins board, after approx. 15 years, I made the adapter and I had nothing on the screen.
I did the regular visual checks, and it had some very bad newbie repairs done. I think they even used PLUMBERS Solder on it, a lot of heat, and physical prying.
So, started with checking the crystal, and it was good. CPU RESET, fine not watchdogging.
scoped the RGB lines and getting a good signal.
Scoped the sync and it looked like it was weak.
Logic probed every chip, every pin, in the sync circuit, and everything looked fine.
I was so frustrated that after 4 weeks of going in circles, I desoldered every chip in the sync circuit and tested each chip in the chip tester. Every chip passed. Putting them all back into sockets, nothing changed. I 6saw the SYNC line with the resistor inline so I jumped it and I got a display. Shitty unstable display, very blue, but something to work with.
I decide to focus on the SYNC issue then I'll tackle the color issue.
This is when I spent the time and tested every trace against the schematic to confirm there was no physical damage that I just couldn't see.
Back to the scope and recording all my data, I saw the HOR SYNC input @4volts, Vert SYNC Input@4 going into a AND GATE. but the output should have been a combination of the 2 at the OUTPUT, but the scope was only showing 2volts coming out. Swapping out that chip gave the same results.
So something is pulling the output down!
I unplug the jamma and start testing for any shorting and worked backwards from the crystal, and all looked fine.
Holy F()$*%*U I am going to lose my mind.
Plug it back in and it is still a jumping visual pile of crap.
I decided to try to figure out the color issue to let my brain relax from the SYNC problem.
But once again back, forth, up, down, everything on the board looks fine.
And then just out of chance I have the board turned off, still JAMMA plugged in and I am testing continuity on the traces and found that there was a direct short of the SYNC line to the BLUE line.
I work backward toward the jamma connector, only to find that the short is in the adapter that I put together.
Holy crap Batman!
Looking at my wiring there was no physical connection at all.
I even desoldered the blue wire and the sync wire (which are directly across from each other) and there was a short between the two pads on each side of the finger board.
SO what the issue is/was when I cut that finger board off of some piece of electronics at some point in time, there was a tiny tiny bit of a through hole via still intact. I needed a magnifying glass to see it.
SO the main reason I decided to bring this up is because I got lazy and it almost drove me nutz.
NEVER Assume that things are correct. when you make any adapter, test it with your meter, your eyes cant see everything.
Always go to the basics and work up.
I just figured that I have made so many of these things that how could it be wrong.
So the person that was closest to the answer was....
LURCH . Way to go Bud! And thanks everyone for the info.
Some times it is good to just ask and bounce a question off you guys to give me either an answer, or a different way to rethink a problem.
