RetroClarence
- Credits
- 2CR
Hi all
I have a ground wire bundled with the two speaker wires in my new JAMMA build. You can see it in the photograph below. On the end of the ground wire is a connector which I've not seen before. You can't see it but coming from what appears to be a female extension connector are two wires with crimped 2.8mm connectors.
I am assuming that this is a ground splitter so I can ground the two speakers and I assume the ground wire coming from the harness is supposed to connect into the splitter to give me two ground wires to connect to the speakers.
The only problem is that I can't seem to connect the ground wire to the splitter. I suspect I'm doing something very obviously wrong but any help would be appreciated.
Thanks in advance.
Chris
Thanks in advance.
Chris
