Gunsmoke PCB issue
Keithgeo
41CR
Hi, quick question! i have a gunsmoke (bootleg i think) and a gunsmokecapcom adapter, but when i plugged it in to test the supergunpsu went crazy, power flickering on and off. So i turned it off quickly, its probably destroyed. Does anyone know if they made a gunsmoke bootleg with a jamma connection on it that doesnt require an adapter? I know the connector looks like jamma anyways from reading online. or what am i doing wrong!? Thanks
Keithgeo2019-08-14 12:55:26
Keithgeo
41CR
Thanks lads, i just couldnt find any mention of a gunsmoke bootleg being jamma online but it must be. ill take a photo of it later, it does look jamma but a search online told me that some of these do look jamma but are not. thanks for the help
kiels20
125CR
This is my gunsmoke bootleg and it is NOT jamma. 5v and ground seem to be in the same place but the red green and blue are not. I made an adapter for mine and it seems to use the capcom classic pinout. Make sure your connector is the correct way round parts to parts and solder to solder. Not the opposite or this can do something similar and make you psu do silly things or f the board up
LHantz
9 (100%)
327CR
I also have a Gun.Smoke bootleg, looks very similar to the pic above, and it is NOT JAMMA, needs an adapter (works for Commando too)
big10p
Coins detected in pocket!
6,094CR
Doesn't look JAMMA as pin 7 should be the key/slot position, whereas it looks connected on yours. Not sure though, TBH. Someone here will know.big10p2019-08-18 17:00:37
Ace`
PlanB contributor #1
40 (100%)
4,043CR
It looks like capcom classic, it's not jamma. The label is in the way but it looks like pins 25 and 26 are joined together.
This pinout suggest's that's correct as both are 12v
http://wiki.arcadeotaku.com/w/Capcom_Classic_Pinout
This one not so much as one is 12v and one is ground
http://wiki.aussiearcade.com.au/index.php/PCB_Pinouts_Capcom_Classic
I'll check a capcom manual to see which is correct, but are you using a home made adapter and if so which pinout was followed...
Edit: Gun Smoke manual says, pin 25 = 12v pin 26 = ground, can you confirm if they're joined on your board?
Ace`2019-08-20 20:28:14
Keithgeo
41CR
Thanks a lot I’ll check that out and post back!
This is the adapter I’m using when the supergun and psu goes crazy flashing on and off.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.ie%2Fulk%2Fitm%2F292893764260
Hopefully that link works.
QuadroGuy
3CR
I can't tell whether it's Jamma or not but you can check out the pinout.
A pal from another forum told me how to do this:
First you have to choose one IC and look up the pin for +5V in the datasheet for the chosen IC. Next you check which pin of the edge-connector is connected to the IC's +5V pin.
Next step: Same procedure with the IC's ground pin.
Knowing the pins for 5V and ground you can fire up the pcb and look for one of the colour pins. When you've found one or all three colour pins you can look for the sync pin.
Now you can continue with all the other pins or just compare what you have with known pinouts.
Hope, this is helpfull...
favouredson
Super Star
1,260CR
You could try looking at pin 7 (key on JAMMA).
It clearly has a connection on the PCB so it can't be JAMMA.
If you look at the manual you see that pin 7 is video ground and pin 8 is the key on Gun Smoke...
Keithgeo
41CR
Hi, thanks for all the tips and advice..
Pins 25 and 26 are not tied together on it.
Pin 8 doesnt seem to have any connections running from it.
yet when i plug it into the capcomgunsmoke adapter the psu goes crazy
Kiels20, my board is nearly identical to yours visually, except i seem to be missing the chip you have in IC84 I Think, if my eyes are working. at h12 in your image.
Dunno why its going crazy, im going to plug it in again now and try it again.
Keithgeo2019-08-21 19:07:30
favouredson
Super Star
1,260CR
You may have a short somewhere on the PCB.
Even if there was not a fault on the board the game would not run as the IC you are missing appears to be the main program RAM.
Keithgeo
41CR
ill try replace that missing part and see what happens. ill check the board for a short too. I did spot a bit of solder that looked to be joined two pins on the connector, i removed it but it still did the same thing.
Lurch666
21 (100%)
4,519CR
A missing rom would not cause the psu problem you are describing so you need to sort that out first.
Have you checked the continuity from gnd and +5V to the legs of a chip to make sure the power is going to the correct pins?
If not every time you plug the board in you could be causing more damage.
Also check the edge connector is correctly aligned with the edge of the pcb.I have some that if not aligned properly touch the wrong parts of the pcb edge and shorts it out.
Lurch6662019-08-23 11:47:51
Keithgeo
41CR
Thanks a lot, ill check over the pcb and continuity and make sure. I should have done that already in fairness! ive a few on the go im trying to get working at the minute. ill give it a good look over the weekend. Thanks
