Hantarex US300 Problem.
DataEast77
14 (100%)
59CR
hey guys, im currently restoring an electrocoin chase hq cab and have just had the monitor back from repair the flyback was fried.
I decided to check the PSU voltages before i plugged the repaired monitor in and the monitor voltages are a massive 320 volts!
Im getting some strange readings on the jamma edge also.
The PSU is a hantarex US300 switched mode power supply.
Would it be better to replace the PSU, using a transformer to power the monitor at 130v?if so what would be a good substitute PSU?
If i did replace the PSU the degauss is powered from the Hantarex us300 at 240v,would it be safe to run this straight from the 240v mains?
Thanks guys.
Mike.
