Heavy Unit Graphics Glitch?
Adamski
428CR
I brought the above genuine PCB from a seller on here and plugged it in to test and it worked fine.I then plugged in yesterday and got a large horizontal bar running up and down the picture and the screen "jumping".I have literally had it plugged in less than 5 mins and the seller sent a vid of it working.Is it faulty and Im just unlucky or is it fixable?
I did take a video of it but cant work out how to upload it here so took a photo instead.Other boards work fine
Adamski2020-07-23 15:30:12
FanDabbyDozy
22 (100%)
170CR
Surely you just need to adjust the hold on the monitor?
The graphics above the black line are what should be at the bottom of the screen, so not faulty just adjust monitor.
mozie
20 (100%)
530CR
Definitely just need a tiny tweak of the vertical hold, should be a series of little pots on your monitor to adjust screen size/position etc.. one of them will say vert hold give that a tiny tweak, do you know what type Monitor you have?
trm
2,877CR
Vsync is slightly out. Earth (ground really) is fine otherwise sync would be waaaay more out, and the colours would be f**ked up too.
The signal is generated in a pretty standard way across most games, but different timings between different boards mean it will vary e.g. if the resistor in the base clock circuit is slightly out or has got a tiny bit of corrosion in it, it will change the RC of the clock circuit which means your board might run a few tens or hundred of Hertz differently to another.
If your CRT vsync was only just within the tolerance of the sync circuit on the CRT chassis then it's all good until you feed it a sync which is slightly further out. Should be an easy fix on your CRT remote board - seller wasn't dodgy
Adamski
428CR
Thanks.I wasnt implying seller was dodgy lol
All sorted now.didnt even know there was a CRT remote board!
This is why I like this forum.........People only too willing to help
