Help me fix a Mr.Do pcb??
Purity
The Oracle
17 (100%)
2,999CR
cmonkey said:
I know my eyesight isn't as good as it used to be (damn you old age!) but I'm failing to see sprites in the video above?
Hehe, it's not obvious in the video, but I carried on with it last night.
I'm certain the glitches that's occuring on screen is the sprites. Like I said I saw one of them go round the maze in a pattern so I'm sure that's what they are. I will try and capture it on video to show you what I'm seeing, so it doesn't look like I'm talking nonsense
cmonkey
1,659CR
I stand corrected! Although I do confess to preferring the sprites from the original release, rather than your freshly designed efforts!
Purity
The Oracle
17 (100%)
2,999CR
Purity said:
I had a long chat with Tim on 29th Nov. I mentioned that I thought the Ram @ A8 and B8 had issues. This was because I could see dead activity on certain pins:
A8:
1-3 dead
4-8 pulsing
9 - L
10-P, 11-H, 12-P, 13-L, 14-P, 15-17-L, 18-H
B8:
1-3 dead
4-8 pulsing
9 - L
10-P, 11-P, 12-P, 13-P, 14-P, 15-17-Dead, 18-H
Tim pointed out that pins 1,2,3,15,16,17 were tied to ground on A8 and B8 as they were using much larger ram than required. However he metioned that I should be getting low readings rather than completely dead readings
I wasn't happy about the dead pins on the rams @ A8 and B8, so I decided to remove them last night and check them out. They are both working correctly. HOWEVER, I found a broken track underneath rom A8 and this was causing the dead pins I was seeing, so I'll bridge this with some kynar wire. I'm not sure it will make much difference to the problems though
Purity
The Oracle
17 (100%)
2,999CR
I found another fault at 9P. A broken 273. I now have a brick type effect on the title screen.
BUT...............
I am now officially stuck with this one. Can't find any more faults on the PCB. Time to give up I think
Lurch666
21 (100%)
4,519CR
BUT...............
Do you still have this board.
I have just started a thread about fixing my Mr Do and although I have different problems I may have stumbled upon a possible fix for yours.
When I was fixing My Nascom 2 the main problem was with PROMs.these are like mini eeproms that can only be programmed once and only hold 32 bytes of data.The Mr Do board has 4 of them (T2,U2 E10 and J10).
These are in sockets on my board and looking at one of your videos it looks like yours are as well.The problem with proms is that over time the data burned to them degrades.
Fortunately there is a good way of testing to see if there is a problem with one.
You can take a 27C040 eeprom and wire it to mimic the proms.Then you burn the correct 32 bytes to the first 32 bytes of the eeprom and use it as a temp replacement for a prom.If you look through this thread on vintage computer forums about my Nascom you will find directions on how to do this.
http://www.vcfed.org/forum/showthread.php?57307-Nascom-2-Troubleshooting/page2
I mention this because when I removed the prom at J10 on my Mr Do board ALL the sprites disappeared so you could be suffering from a duff prom.
Purity
The Oracle
17 (100%)
2,999CR
I swapped the PCB with Ace and he told me two proms were in the wrong place
He swapped them with each other and the game was perfect
So yes it was the proms
Ace`
PlanB contributor #1
40 (100%)
4,043CR
I had another Mr Do pcb at the same time with missing / scrambled sprites and that was unrelated to the proms, it turned out to be a bad 74LS32. So the proms aren't always to blame but they were in this case.
