EDIT: I'll modify this as I test thing, so any new people can see whats been done
ISSUE: Boots to "Missile command" title for 3.5 seconds then flashes and repeats the sequence.
NOTE: I can start a game while on title screen, it lasts a little longer, perhaps 4.5 seconds before rebooting again.
CAN I FIX?: NO, Im not a repairer, but trying to gain an insight before sending off. Any recommendations of who would do this board would be appreciated.
HISTORY: just got the table from a forum member before new year. Worked first time, didn't work 1-2 weeks later. Retro clinic sticker on board from 2017.
TESTED SO FAR:
1. WDOG to GROUND
YORSHIRE_SPAM "There's a test point on the PCB marked WDOG_DIS (or WD_DIS or something) if you connect that test point (temporarily) with a bit of wire to one of the test points marked "GND" it disables the watchdog circuit."
- no change
2. VOLTAGES:
5V = 5.05V
-5V = -7.9V
12V = 11.99V
TETS SCREEN SAME AS THIS:
But "6 cities" and under that mine says " 2 6 "
This screen not mine - difference mentioned above
Is that saying bad chip map ok? In other words, no bad chip?
answer by YORKSHIRE_SPAM...
So it seems like it is the pokey, not sure if anyone has a different input or if that's 100% correct in everyones eyes.
I have removed the pokey, and all seems ok, but noticed trace repair under the chip.
Im thinking this may have failed, or a trace not done previously has gone bad.
So next I am going to check continuity on all the pins.
Any other thoughts?
Sbdesign2021-01-02 10:13:55
TESTED SO FAR:
1. WDOG to GROUND
- no change
2. VOLTAGES:
5V = 5.05V
-5V = -7.9V
12V = 11.99V
Any other thoughts?
