Help with voltages...
funk
555CR
I have a generic jamma cab with generic components, football champ PCB and a wells k7000.
I was looking to replace the coin door bulb, not knowing it's 6v or 12v I took a multimeter to it. Weirdly it was measuring 8v, on @funhouse's advice I checked the voltages. Photo of PSU linked.
https://photos.app.goo.gl/zJYos5mCsmYb8n7v7
With the game running, the +5v rail was measuring closer to 8v, the 12v was closer to 17v.
Turned everything off, unplugged the board, measured the voltages, turned the pot down and the lowest I could get +5v was 6v.
Figured it was worth a go, plugged the board back in, wouldn't boot. Reversed the process taking the +5v back to 8v.
I have some new kit arriving in the next week and have a JammaASD to play with but am dubious as to plugging anything in now.
I understand different boards pull different offsets of power but this seems a bit extreme?
funk
555CR
FrancoB said:
Is your multimeter reading ok? Sometimes a low battery can give funky readings. If you can, meter a source with a known value.
Did cross my mind, it's an old cheap thing I got Inna set years ago. Will check it out thanks.
funk
555CR
Quick thanks @FrancoB, you were right on the money, battery replaced, 8v now reading 5v
strykr
1,351CR
They really should say this in the manual. Caught me out with a brand new switcher, voltages were all over the shop.
It was the battery
funk
555CR
big10p said:
Yeah, it can be a real gotcha. Kind of easy to forget multimeters have batteries.
 Nice catch, Franco.
I feel really stupid about it, but it's close to 10-15 year old so bat wise it's understandable. Just would have thought the display would have been fading, had no idea it'd just measure completely off.
