How to remove rust?
Ace`
PlanB contributor #1
40 (100%)
4,040CR
Citric acid in water, the more you use the quicker it works. When you take it out it looks like it hasn't done much but if you use a brush you'll see all the rust just wash away.
aeroflott
A different league
16 (100%)
1,069CR
Retroman839 said:
This. Some coca cola and kitchen foil. Dip your foil in the Coke and rub the rust. Watch it fall away.
It also works with just water, but takes longer.
Spanky
657CR
When I posted the question a moment ago, I anticipated the "coke and tin foil" reply, but I thought there might be something a bit more scientific.
Carlito3
115CR
I use Evapo-Rust.
https://www.amazon.co.uk/EVAPO-RUST®-C700-Ready-Rust-Remover-946ml/dp/B00GRSOJSS/ref=asc_df_B00GRSOJSS/?tag=googshopuk-21&linkCode=df0&hvadid=309775958298&hvpos=&hvnetw=g&hvrand=12010471209471310285&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=1006816&hvtargid=pla-499804341797&psc=1Carlito32022-10-23 18:43:35
PAC-MAN
558CR
John Bennett said:
Wire brush on an angle grinder if it's a big piece of rotten metal, like most of my cars.
Same as this guy^ every time. If it's a smaller piece, a drill with a wire brush attachment.
eccentric-nut
19 (100%)
382CR
This is an excellent product for treating rust. Just a quick tip when using this is to pour out a smaller amount into a container and then apply with a brush, do not tip any excess back into the original pot or use the brush directly into the pot, onto the rust and back into the original pot.
eccentric-nut2022-10-23 20:15:22
Vamino
Insert coin(s)
2,700CR
Yeah, this stuff is very good for killing rust if you intend to paint over it.
Sand off the rust, clean the surface and then simply paint the liquid on and leave it for a bit.
The following pics show how things look after 1 light coat of paint.
5,332CR
And if it's heavy....centre-brace on 20 year old Golf before and after 10 minutes with wire brush on an angle grinder.
Obviously never take an actual grinding disc to anything on an arcade machine, but the wire brush is much more gentle, almost polishing the rust off. Goggles are needed to avoid bristles and rust into eyeballs though
That kurust stuff it worth a go afterwards, then zinc primer, then paint.
yoganuggy
654CR
Just bought the angle grinder and wire brush accessories at the middle isle in lidl today for this very purpose.
They had a sale on a compressor too. I thought about it for sand blasting but then came to my senses.
mlynn
121CR
I made a right mess of a spare Atari ST internal floppy drive. The 50% Vinegar, 50% Water worked well and I should have left it at that. I rinsed it thoroughly and left it 1 hour.
I then used lemon juice and baking powder to make a paste and then layered it on. It seemed to work but left black spots all over it. It seemed to tarnish the metal. So be very careful about using home made remedies. Any advice on how to 'reverse' the tarnishing would be appreciated.
My dad used to use Duraglit wadding to polish up metal. It was excellent. I don't know if the Brasso wadding is as good or the same formulation as good old Duraglit.
cliff_poole
1,069CR
Same advise as everyone else. Wire brush first, then rust treatment stuff. I think they all use phosphoric acid so pretty much the same, and some sort of gelling agent so you can brush it on and it not evaporate too quickly. It should prevent the rust from coming back too. There are some primers too that claim to contain acid but I have never tried them. Raleigh bicycles used to dip their frames in a vat of phosphoric acid before painting which explains why so many of their old bike's are still around, I've got one from the 30's.
For chrome, fine steel wool is best. That might sound scary it you have never used it, but it is really soft, more pleasing to use than aluminium foil IMO.
