HV Probe and Multi Meter
Bulla
68CR
I'm trying to get some kit together and wondered if anyone can advise me please ?
Is a HV Probe really necessary or will a big rubber handled Screwdriver and Crocodile clip do just fine for monitor discharge ? One is significantly cheaper than the other although I'm happy to pay the extra to avoid death
I spotted this meter online
https://www.amazon.co.uk/AideTek-VC97-Digital-Multimeter-Capacitor/dp/B008GTEZPI
Will it do fine for basic troubleshooting of Dead PSU, Monitor, fuses etc ?
Flinnster
The Dino King
29 (100%)
2,566CR
Multimeter looks fine, mine looks darn similar.
On the probe, I've seen people do it on every way from the proper tool to a screwdriver with a bit of mains cable attached. Personal preference there I'd say.
The last monitor I removed I didn't even bother discharging, I just made sure not to lick it or stick my nads anywhere too close to the tube
martin8or
144CR
I think you need to have a meter with a certain input impedance to match that of the HV probe otherwise you will get an incorrect reading,I think 10M ohm is what you want and I'm not sure if that meter has that. I wouldn't go measuring 1000v DC with something like that. I like my 8060a, now that is a proper meter.
Brettster
1,276CR
Ideally you should use a non auto ranging MM when using a probe as this will reduce the voltage from 20000v to 20v for example
I have a nice fluke probe that I got cheap, and so far every single monitor I've tried it with has been self discharging and I dont see anything on the meter, so to make sure it's discharged I end up poking it with a screwdriver with a croc clip on the ground wire around the back of the tube just to be on the safe side.
so as long as you take the right precautions and have one hand in your pocket, wear a nice thick rubber glove and make sure the cab is fully switched off etc, you'll be fine with the quick results from the screwdriver method.
The probe is nice if you want to check the live voltage, or slowly discharge the tube, if it's old enough to keep one for long that is.
The screwdriver will discharge is in a quick pop.
Brettster2018-03-17 20:02:20
Bulla
68CR
Thanks guys, so I think I'll go for the screwdriver method and the auto ranging meter is fine if I'm not using it with the HV probe ?
All I really want to be able to do is basic diag tests safely so I can then whip parts out to send to someone who knows what they are doing !
Bulla2018-03-18 11:25:58
