I've got an ID2 that I'm in the process of converting. It was a slave so is clearly missing a few bits (as I expected).
I've had a look at the wiring diagram but it isn't 100% clear from that exactly what is missing from the slaves. From what I can work out, the following need adding:
1) 3 pin IEC power connector
2) Mains rocker switch
3) VTS board (mainly for the volume, test, service, degauss)
4) JVS PSU
Is that about it?
Out of interest, what does the master provide to the slave - from the above I assume it is power for the motherboard, test/service/volume etc and mains power?
4) JVS PSU
Is that about it?
