An easy question I'm sure for the combined brains on here, but what's the definitive way of identifying whether a transformer is also an isolation transformer?
My understanding is that in Domestic Power Supply, the Neutral is also connected to real Earth, which means that connecting a hot chassis to the Ground of a normal appliance / scope / etc. = shortest path to ground = potential for shock
So, with the isolation transfer there is no direct connection between any of the physical wiring, so Neutral becomes no longer connected to Ground and thus safe
So - following that logic - on a non-isolated transformer you should get connectivity between Ground on both sides of the transformer, and Neutral
On an isolation transformer, there should be no connectivity between Ground or Neutral of either side
Close or totally out there on wrongness?
(P.S. if you can survive this video he demos the above)
Judder2017-06-30 17:11:03
