Interchangeable Jamma CP connector options
huggers
31CR
Hi all. I have a jamma cab and I want to be able to plug and play different control panels. What are the best connectors to use for this? Some kind of molex? Is there a good pack of male/female connectors and pins etc? Is there a a better solution? Thanks for any advice
andyman
1,059CR
Amp Mate n lock are good but any connector will require the correct crimper and thats where the cost is, unless you solder the wiring to the pins, if its a 1P panel, you can get away with a 12 way
No other solution really
Macro
2,016CR
When I did that I used inline scart connectors, 20 pins + shield, but my two player panel had 4 buttons each.
you can see how long ago it was when I did it, as the plugs / sockets all came from Maplins!
Titchgamer
123CR
I like JST connectors but theres lots of different types.
Get yaself some good crimpers though, These are very good:
https://www.ebay.co.uk/itm/222499991999
ColinD
6 (86%)
1,367CR
Molex Mate n Lok as Andy says or you could use Mini Mate n Lok or D type connectors are always good with the appropriate posts fitted.
Something like this wired inside your machine would be ideal... you then fit each panel with a 25 way plug and jobs a good un.
£6 with free prime delivery = no brainer !!
https://www.amazon.co.uk/SIENOC-DB25-M2-Breakout-Terminals-Connectors/dp/B01N5CBPQE
If you want to be really lazy.... combine with it's male equivalent (£6) in each control panel (https://www.amazon.co.uk/SIENOC-Breakout-Terminals-Connectors-Terminal/dp/B01NCISZPM) and link together with a 25 way cable. No soldering required !
ColinD2020-06-03 15:22:29
Flinnster
The Dino King
29 (100%)
2,566CR
I use the standard Sega JST connectors in all my Dino Jamma's, and can hotswap the CPs as I need. JST connectors are a bit stiff to unplug mind... D-shaped ones sound more sane if you're not having to fit what already exists in a cab.
Flinnster2020-06-03 15:43:03
FrancoB
17 (100%)
1,040CR
Personally I would go with JST YL series like in Flinnsters pic purely because I have about 8000 pins for them
They are nice compact connectors and the contacts crimp really nicely with a decent tool. They're not the easiest contacts to remove if you need to however, there is an official tool you can use but I just [made one from a piece of feeler gauge].
Another option, and which may be a better one for you, is [AMP UP (Universal Power) connectors]:
They're the connectors commonly used in a lot of Sega and other cabinets. They have a nice form factor, they crimp nicely and the contacts can easily be removed using a simple paperclip:
[tube]PcJUhtHCzfI[/tube]
Note: I find a 'standard' gauge paperclip works much better than the thick type used in the video.
Both of the above connector types and contacts are available from [RS Components] amongst other places.
8,309CR
cheers franco i will check it out
yeh i bought a load of 4 chanel amp up universal from rs components for speaker connectors i’m making and orderd male female pins and got it wrong again...
plus the neo geo don’t need an amp!
but i had fun making them lock down loco
can you please recommend 22 awg or 16
will be 1p / 2p loom connectors astro/ blast / egret
will be for this pannel i’m making
only 1 mm thick stainless steel next time i’m going for 1.5mm steel as a bit to thin.Retroman8392020-06-05 19:46:57
FrancoB
17 (100%)
1,040CR
I use 16/0.2 (approx 20AWG) wire for controls, video, audio etc and 24/0.2 (approx 18AWG) for power/GND.
FYI 16/0.2 means the wire consists of 16 individual strands which each are 0.2mm in diameter.
FWIW, I get my cable from [Rapid Electronics] in 100m or 500m reels. I use their 'own brand' 'equipment wire' which they offer in a wide range of colours.
If you want smaller amounts there are plenty of ebay sellers that sell equipment wire such as [this one] which offer both 16/0.2 and 24/0.2 in a range of shorter lengths and different colours.
Just to preempt another question....
I get most of my quick disconnects from Polevolt. They do some really nice crimp terminals and sell covers for them too.
They sell the 4.8mm and 6.3mm terminals for larger microswitches but for Japanese buttons you want the 2.8mm ones, [this] is a direct link to their 2.8mm offferings. You would want the 'Tin plated female blade terminal 2.8 x 0.5mm 0.5-1mm' terminals and I prefer the 'White housing for 2.8 x 0.8mm terms. Post fit. 10 pack.'
covers.
(Make sure you get the terminals suitable for 0.5mm with termianals and not the 0.8mm ones).
I find these far superior to the red/blue pre insinuated terminal disconnects. These ones have much stronger mechanical strength and I think they're far more aesthetically pleasing too.
FrancoB2020-06-05 20:21:21
8,309CR
quite, those red and blue are ( cough bit down grade ) for lcd bar top brigade!
thanks that clears it up nicely....
and yeh time for a crimper for me
FrancoB
17 (100%)
1,040CR
Just noticed your photo edit.
Yes, 1.5mm stainless would be better. What are you using to make your holes? It looks like you're getting a lot of distortion around the start button holes.
A decent quality Q-max punch should be ok in 1.5mm stainless, just make sure it's well supported and you have it clamped to something solid with the punch as close to the clamped surface as possible. There are a couple of photos in [this] old thread, you can see how I have the hole to be punch right up against the table.
FrancoB2020-06-05 20:29:32
8,309CR
yeh!
i have the q max now
but was impatient before and tried a colbolt 27mm
and distorted but q max is fine...
this is just my first practice...
what do you think about using aluminium ?
over steel?
pins just orderd...
at the moment i’m salvaging wire from all over
car stereo looms
electronic cables
wooster bosh boiler power supply’s ... lol
but i will buy some new wire soon...
i’m looking at buying variac for gentle bring up
chassis
hakka de solder
a good solder station...
basically i’m still building a work bench...
i built 2 sheds and 1 full of cabs can’t move!!!
and other my work tools plus monitors
and other crap i have to store!!!
Retroman8392020-06-06 08:19:15
