Irem M92 board - glitched sprites.
yoganuggy
639CR
I've an irem m92 board with glitches sprites.
All eproms are good dumps.
Usually I'd shotgun all the ram but the ram test at boot time passes. Should I do it anyway? Would anyone know what ram or ttl are involved in sprite generation (there is no schematic for m92).
Thank you!
Ace`
PlanB contributor #1
37 (100%)
3,799CR
If the little jumper isn't missing or on the wrong pins then you most likely have a bad GA22 custom chip, very common failure.
yoganuggy
639CR
Do you mean the j3 jumper on the main board? That's in place (if I take that jumlper off the sprites disappear completely).
If it's the custom then this is toast. M92 boards on ebay are ludicrously expensive.
