Isolation Transformer replacement recommendations
K1ngarth3r
922CR
I've got a Farnell AT/D4003 148-952 Isolation Transformer that is not pumping out the expecting voltages any more.
I'm looking to replace it with similar spec.
It takes in 120v (x2)
And pumps out 12v (x2)
Can anyone recommend a replacement please?
davey d
480CR
Do you really need 2x 120v inputs and 2x 12v outputs? Surely a bigger VA transformer with single 120v input and single 12v output would do the job?
K1ngarth3r
922CR
Probably not, I’m just looking for like for like to keep things simple I guess.
I found this one but not sure about the amps...
https://uk.farnell.com/vigortronix/vtx-120-003-612/transformer-3va-2-x-12v/dp/1712727?pf=110304950%2C110286162%2C111978503&krypto=73iO1kHnVjpYb7JbNhCPdJYJy3On3JenwcyF8L2l%2Fd%2BM84zddBkJUi38%2BjYqI6j78gKvdO8XCSj%2B4PI71cSFqXd0MHXbetLIKIRMNdiRMdkT5J4qOJ2kh%2F1MvAH%2BVcKAW4lqC6b4%2FAZH3ZBXb4g9jUMyiWdY8ATvaU2xqDIAZi7oXK2c9eloCGRfxfePjMAQk%2B74kqpvWWtal4DUY%2BWPI%2F8agFtZ2DbgVjjUd0jFj0N1NGNn%2FMZDNJNaygAlgMAMcYxy4xD2X8PZo7L8CrLx09X5yjLzy3sFWorCYKB%2BC5xlBgc87cgvAjKbqawNYH3NlDRtlGGTgXpAgx9f%2FwIw8lfcp7hBLor4AHhGzuUoOmMwNk8NeVVYGmWen1%2FxssF0ILrlgqKQdWmX12BfqRDeOwEtPdKAZV%2FGfZmWgsNLZpalVp8fsPygXVhs6FZKSv2J8I%2BEYkRlLd%2BW3ncpAErUwxbz8SpnjxX5GK0cdINyKCcZhF%2FKoQb3OV7TnIaY%2BRLWhvPdNR3J%2F1XobztP%2BHxVIocqFGOVgbzERd%2FPy41%2BhPlyDobqyLF%2Bem4IueBzrZ98R4jkwqXu%2F943G4yx0ia01U91JXSlfhngYI6mwb64M%2FoyZFaAQdyxKz50Rx2Z%2FW8%2F9gKcEgArKGuKP8oLoDR770qZv416v9C%2BoJHLqNVcE4HImLkNV550%2BN8M%2B%2FKx4frcAfd5%2FB99GBOgu8A3PbpSdCjhu9GACqUIc406LWygbYGps5ljFPalIWFUItshnTnDEER%2B6NO0UVtEfVG%2B0t5cy0w1HLq5ubnXBIJpTF1FnsrFsPwrY5sNhOM0GwuPPXkGx7NvFwGweFh3KqIRLqZfragsPu2%2FJGP2pY8d9%2Ffw4xc8z2Z00eglisrS2gJcvWc%2Fb5t%2FfreBjhlLVfm2O82D04%2BNEwRDK7l%2BULXnjok%2Fu9WMZ5C18Q%2Fwu6yt6dhtL3WcfDrEd%2BnR1qY2fMnUL5FofuxNTM6M%2F5dKizOdF7qiQyG%2FmF9Ufp3guSx4O4x%2FE5UpSpeqfzyVoQidr5P%2FKNpqmwHEVCwxPPtrFV9vZs25nAzJGOJvRBK1YbMs%2F8gT6aq%2F%2Fu3wf5fRc3Ln87qmdckEtQ7x5bkEo2dYoVRSt8qamnWul%2FgvyRCBewy%2B9RJeQijCbShiSjWUiziVaMENdCX1qJbUfOycxoJpzKnNevjJf%2F0%3D&ddkey=https%3Aen-GB%2FElement14_United_Kingdom%2Fw%2Fc%2Ftransformers%2Fisolation-transformers
K1ngarth3r
922CR
An audio board and a coin door light.
Audio board needs 12v (TAOS board from ALG) and coin door lights need 6.3 according to the manual but I guess enough to power a 5v board would be ok.
K1ngarth3r2020-03-09 22:04:07
K1ngarth3r
922CR
Thanks for finding the specs on this! The one I've ordered is 50VA which I guess is around 2amps per 12v feed (I think).
Hopefully this will be good enough, I ended up ordering both the ones I linked to.
