Jailbars on SF2CE Boot
J69
281CR
I've owned this for a couple of years without issue (apart from MP gives you a MK for some reason).
Turned it on today and I've got jailbars through the lifebars and screen titles. I've cleaned the jamma edge, made sure all the roms are seated properly and it's still the same.
Where do I need to start looking?
TheDaddy
14 (93%)
7,230CR
Could be a number of things , first check voltages are good. The bootleg versions do need a bit more wack than others. Being a bit under can cause this.
Dave.
J69
281CR
You were right. Chucked it in a different cab and it works fine.
Any ideas how to turn up the voltage on a NNC? It's not immediately clear looking inside.
I've got a converted R Type pcb with some background glitches so I'm hoping this may be the same issue
