Kamikaze PCB
jonhughes
1,156CR
I've relooked at a Kamikaze PCB I bought a month or so ago. It's actually called Kamikaze III. I'm not sure but it appears it could now be fully working after a resetting issue. I had a resetting problem on a Rastan PCB (I had fixed previously) that had probably been dead for some time but after leaving it powered on for a while the problem appeared to disappear - same thing with this it would appear. Capacitors possibly?
There is one thing though. In the top left corner of the PCB there appear to be two capacitors missing. I can see the remnants of one leg in the eye. I do not know the size or the orientation of the caps to go here - should I leave well alone or will this affect the PCB over time?
jonhughes
1,156CR
Correction, the PCB continues to reset but the longer the power is applied the longer the interval to the reset, until it stops resetting. It's approximately 1 minute of power on, to stop the resetting issue.
Equites
Chief Sheesher®
35 (100%)
3,329CR
I've had a quick look at this for Jon. All logic seemed to be fine to me, also all RAM except for one Attack RAM (82s17) IC from a bank of 5.
Two of the ROMs (where the daughterboard would normally be on a Midway board, ROMs Z & Y) at locations 7M and 7L had previously been replaced by someone.
When I ran all the ROMs through Romident, all checked out except the two new ROMs which were unidentified.
Removing any of those two ROMs results in the game not working.
Can someone run these ROMs through MAME and let me know what the results are? I find it somewhat confusing how to do this, what with the different revisions and archives required.
Also, how do you force MAME to run code which fails CRC?
Kamikaze_III_ROMs.rar
Equites2014-03-20 17:05:15
cmonkey
1,659CR
You need to add the prom from the galaxian mame rom set (6l.bpr - 32 bytes in size). Drop that into the folder full of roms that you've created, zip them all up and rename the archive to kamakazi3.zip. It plays fine in MAME for me after doing the above steps.
Equites
Chief Sheesher®
35 (100%)
3,329CR
Thanks Ade, did the ROM set run without any problems in MAME?
cmonkey
1,659CR
Yes, once I'd added the prom from the galaxian rom set then it played fine in MAME as kamakazi3. The whole set of roms dumped by you matches the MAME kamakazi3 rom set CRC's exactly.
Equites
Chief Sheesher®
35 (100%)
3,329CR
Agreed, the ROMs are fine. I'm still looking for what is causing the PCB to constantly reset.
jonhughes
1,156CR
Hi all,
I've just tried and removed the ROMs from the Kamikaze PCB. I don't know why I haven't tried this before! There is a problem with one or more ROMs. The ROMs will play in any standard Midway board and it results in exactly the same glitch. Can someone please burn me a set of these ROMs, it looks like it could be a problem with the chip and not the data on the chip.
Please anyone.
Thanks in advance.
Equites
Chief Sheesher®
35 (100%)
3,329CR
jonhughes said:
Hi all,
Please anyone.
Thanks in advance.
Ha! No wonder I could not find the problem. I should have used the Fluke, it would have showed me that at least one of the ROMs is no longer working to spec.
Worked fine in a programmer though, but not working to its spec obviously as a programmer will read slower.
