kapton tape
alfa75
19 (100%)
96CR
I'm looking for an ideal kapton tape (or similar) for gluing the cable connections on the PCB. Any idea what dimension could be ideal? Thanks!
NivagSwerdna
855CR
Get a wide roll off eBay on the slow boat from China and cut to size as required. A wide roll is useful for hot airing when doing SMD rework.
I presume you mean putting a small patch on the push down part of ribbon connectors? That's where I see it used. Probably quite good in tension.
Just my 2p worth.
NivagSwerdna
855CR
How about UV cure glue. Sold as Quick 5 second glue on EBay?
Beware it is quite permanent.
It's really fun stuff. You position the thing you want to stick and then shine the UV at it and hey presto.
alfa75
19 (100%)
96CR
Thanks for the tip, I just ordered one. Let's see if this is useful.
