Kee/Atari Sprint 2
yorkshire_spam
765CR
Starting point....
Game looks dead, but watchdog is "barking".
Replaced CPU socket so I can use the fluke on it.
Address error on rom test
A3-6 buffered through 7408@B2 - removed, tested faulty, replaced 74ls08
Rom tests now run, but error.
Next step, remove 6290-01 (first ROM) and test out of circuit.
So I built a 2600 rom reader with an Arduino.
The ROM reads 100% ok out of circuit, but still fails in the PCB
I desoldered the 6401 decoder prom - that tests 100% ok
7432@a2 used in adr7,8,9 looks faulty on logic comparator - replaced
At this stage the ROMS test as good in circuit, but ram test fails
No _WRITE signal.
74-174 @ A7 replaced - _WRITE now working.
I hooked up the logic analyser and found that although the RAMS were getting good write signals reading back the same address gave a semi-random value (at the chip according to the logic analyser)
So I socketed and replaced the RAMS.
At this point it passes RAM test, but the screen is still blank.
I found that the output on 74166@r3 was low - nothing.
I replaced a number of logic chips that feed various signals to the 166 and tested the 166 both in and out of circuit.
bad 74-10 @ r7 - replaced
bad 74-32 @ p3 - replaced
bad 74-175 @ n2 - replaced
bad 74-32@l2 - replaced
I replaced a couple of buffers and hooked some credit switches on the test loom and it's running!
Still to do:
  • LDV1B is stuck - so the back half of the white car is missing
  • Check all the inputs
  • Check the audio output
It's been a fight to get it this far - first bronze age board I've fixed to I've learnt a lot.
yorkshire_spam
765CR
I've sorted out the input issues and the Car1 part missing.
Car1 was a dodgey 9301@k8 - once I'd found the dead LDV1B it had to be that or the downstream 74-165.
The input issues were only on the inputs routed through the 9312@H9 - Trak Sel, Start 1, Start 2, Self Test and Gas1/2. Replacing that sorted it.
Here I am "playing" it on the bench using the X-axis of a trakball for steering!
I'm working on the sound issues now....
yorkshire_spam
765CR
The b*stard "bit" me. While investigating the audio problem I touched the top of the tda1004 amp at D9... f**k me that was hot. I've got a nasty rectangular burn on my finger and no feeling in the blistered area. Little sh*t. I think that means I've found a fault on the audio side.... the other tda1004 was warm, but nothing like this.
