Killer instinct 2/jamma+
mysticmonk
1,051CR
I've had this board since the beginning of time, received broken, and my sporadic attempts to get it going never paid off.
It's easy enough to diagnose the common hard drive failure by the pattern you get on screen. However, I don't get that pattern, it's different again. Installed a new flash drive, made no difference.
Have never seen this pattern before, with one single exception! There was a killer instinct 2 cabinet for sale (and sold) on jammaplus a year or two ago. The pcb wasn't working, but the pattern was the same as mine.
So it's a memory test if anyone remembers anything about that cabinet. The pictures were in a large shed, I THINK it sold for 800? And I THINK it was for sale with 3 or 4 other cabinets (an air climax cab?)
A real longshot, but if anyone got that cabinet, it would be very helpful to find out what happened to the pcb. Was it a write off, repaired, an indication of what was wrong?
Clutching at straws here, I know! It's just that the game is so expensive now I'll never be buying one, and I'd hate to be giving up a chance of a repair. Thanks in advance
Monstermug
1,807CR
The common fault with killer instinct boards is the Q flat pack chip underneath that massive heatsink. It always get knocked around (because it's so damn large) and legs comes loose. Will need a good rework station or very good soldering skills to sort that out.
mysticmonk
1,051CR
That actually rings a bell about the heatsink. Maybe later I'll go over it forensically and post pictures. Thing drives me nuts just looking at it sitting it there
I did get in contact with iron giant a long time ago but he wasn't so sure about working on killer instinct boards.
If anyone else fancied a go at this, especially with specific experience on these boards, let me know!
mysticmonk
1,051CR
Okay so I had a much better look at the board, And yep! Theres definitely something sketchy going on at the corner of the heatsink chip. Very difficult to see, even in person, so small! Took a picture, and a few random ones in case some eagle eyed sleuth notices something.
So, the question: If the corner legs were crossed/joined on that heat sink chip...whats the likely outcome? Fried altogether? No impact, other than to resolder?
Have a look...
mysticmonk
1,051CR
So, after testing it again, there may be an additional problem, or else its part of the same problem.
When I power it up, I get a plain grey screen. When I give the slightest of pressure to the board, I get the familiar patterned screen. That's it, nothing else happens. No warning about the hard drive (red light).
Monstermug
1,807CR
Some QFP chips will have a few legs shorted by default. Can't really see the pics that well. Have you tried adding slight pressure to that heatsink and see if it changes anything on the screen?
If you have a 12mp camera on your phone you can actually use the zoom function on your phone to magnify the image quite well. Better than my small magnify glass I have.
mysticmonk
1,051CR
I appreciate you having a look. So, I tried it out again, and this time...nothing! It wont come on at all now, just black screen. Applying pressure here and there, zero. Its definitely looking like something is "loose" at the very least.
Zooming in with the camera there is definitely something up with that corner of the heat sink chip. Its so small that from some angles it looks okay, others, not so much! Hopefully these come out clearer.
Monstermug
1,807CR
Yes it does look like the heel and toe of the joint has been slightly lifted but could be just fine. Check continuity to be sure. That bridge on the adjacent pins does look suspicious though. Maybe someone with a KI1 or 2 board can check if it's supposed to be bridged.
Have you tried to test the roms? Not sure if that would do anything though if the CPU isn't kicking in (which is what is under that heatsink).
Monstermug2019-01-05 20:33:57
mysticmonk
1,051CR
I do remember replacing roms at some point, "knowing" that they were good. Very hazy because it's so far back. Unfortunately have no way of testing them now.
I'll get around to checking continuity tomorrow hopefully.
Maybe it's best to just offer a bounty on this pcb if someone wants to give it a bash to get working! Maybe retro clinic is worth a try? mysticmonk2019-01-05 21:03:20
mysticmonk
1,051CR
Yeah I might just contact phil again alright. Its a strange board, there doesn't seem to be that much knowledge about them breaking, at least from what I can find. Seems to be a ton of guesswork involved. Annoying!
mysticmonk
1,051CR
Phil got back to me, he's in the same boat stuck with non-workers. Pain in the bum hole with these boards. So if anyone else knows of anyone else that knows how to deal with these, I'm sure there's lots of people waiting for solutions!
I know of a guy in America that seems to know these boards inside out, but the prices he charges are getting close to just buying a working one :/
