Konami pcb capacitor
mysticmonk
1,051CR
I can't look into this until later, but this xmen pcb has a large capacitor half torn off. Board looks minty otherwise, but as it stands it boots to nothing, black screen.
So, would a capacitor be capable of causing such a problem?
I don't know much about the technical side of things, but I'm thinking that would be unusual? When I look at it more carefully later, should I be looking for anything else?
TheDaddy
14 (93%)
7,230CR
Possible but unlikely. I have only had a few that caps have stopped them from booting. I just replace them anyway to rule it out and it cheap enough.
Dave.
TheDaddy2020-01-07 19:27:20
Monstermug
1,807CR
Konami games won't boot on certain faults relating to the custom 054986A sound IC. Not sure if that cap will prevent the custom from functioning properly though.
SUPERSPRINT
1,035CR
I know everyone goes on about the Fujitsu ttl rams on these boards but they can also be a reason why the board is dead. I know this because I’ve resurrected a dead tmnt by replacing the fj rams. The custom sound ic issue usually means no sound.
mysticmonk
1,051CR
Had a better look.
Everything looks good, very clean board, no warning bells...
But after going through the usual basic checks...
Sneaky! Perfectly hewn so as to be practically invisible. Never ignore the basic stuff :p
Doesn't mean that's the problem, but feeling a lot more confident now :)
TheDaddy
14 (93%)
7,230CR
I have never had a board with this fault , Mine are all 12 month projects ! Never simple , I just have bad luck. Hope its just that though.
Dave.
mysticmonk
1,051CR
So, finally got around to the obvious: swapping roms from a working xmen to this faulty board....
Hey presto! Playing fine again :)
Only problem is the sound, very low. I'm aware of the Konami sound module problem, but this one looks pretty fine. I'm going to assume the torn capacitor is the problem here. I'll get around to it in the next decade sometime.
caius
588CR
That capacitor has nothing to do with the missing boot, it's just used as filter of the +12V rail.
The low audio is due capacitors on top of module or bad OP-AMP underneath the module.
caius
588CR
Yes.You can check yourself.The positive lead of this capacitor is tied to +12V, the negative one to GROUND.As said, it filters the +12V suppressing any disturbances.Anyway, replacing it won't hurt anything
The low audio is caused by the audio module.Replace capacitors on top for first or install a repro of mine!
