Konami Vendetta need help
Gigi502
10CR
Hi everyone, I purchased this board with other untested board.
I plug it in my setup bench and the result is in the short video below.
Seems to reset every 5 seconds or so. It's also out of Sync but some times i get the image to go in Sync with the TV. (my test bench is fine, i got no problems with the working boards).
I think i should check around the 053248 CPU, any ideas?
I got a multimeter and a oscilloscope.
Thank you for any hint you can give me.
Lurch666
21 (100%)
4,519CR
First check video GND is connected on your jamma since this missing can cause graphic errors.
Then check the signal going into the LS07 at U101 pin 3 and the output on pin 4 to see if it looks like a good sync signal.
Gigi502
10CR
Thank you for your reply.
in my (nothing fancy) home made test bench the jamma video ground pin was not connected, so i took a wire and linked it to other grounds. that made the out of sync problem disappear.
looking at the board, i have no U101, i have four LS07 in 7C / 8C / 7D / 8D positions.vendetta2.jpg
Gigi502
10CR
i am now here...
it seems that the eprom in 17c is not making a good contact, or the pins in the socket are a little loose, because i can remove the eprom almost by hand.
sometimes i switch from the original eprom to a reprogrammed one and the output on the video change colours for example. one times i also got kind of characters/letters on the screen.
sukhbir
46 (100%)
1,737CR
From looking at the video the game appears to be watch dogging,so possibly you have a bad socket at location 17C.
The eprom at 17C contains the main cpu data so if there is poor contact on the socket the game will never boot.
have you did a romident on the eprom at 17C?
Gigi502
10CR
I will try to change the socket at 17c, I hope to not make any damage with the desoldering station.
As for the original eprom i can not read it with the t48 because It gives me bad PIN errors, that's why i programmed a new eprom.
I don't remember if i tried with the "bad PIN detect" unchecked. I Will try again and Will come with the results.
sukhbir
46 (100%)
1,737CR
You need to be quite skilled in removing sockets as with Konami pcbs the Vcc and Gnd pins are very difficult to remove unless you are experienced and have the right equipment.
Lurch666
21 (100%)
4,519CR
Those PCBs have four layers with a big ground and +5V layer that sucks the heat from whatever you are using to desolder the GND and +5V pins.
I use a desoldering gun with a heat gun in the general area to sort out those pins.
If you have any scrap PCBs that are four layer (look at them through the light to tell if it's a four layer PCB) use them for practice.
Gigi502
10CR
this whole area beneath the 17C and up towards the jamma edge seems to have suffered from being in contact with something that exposed some traces and rusted many pins under the 005273 arrays...
