Kung Fu Master problem
Brettster
1,276CR
I have a Kung fu master original pcb
Works perfectly so long as it's in table mode
If I switch it to upright it only boots to test mode
In test mode I can see that all dips are registered correctly and the text for display type switches between table and upright.
It seems if any switch is on for bank 2 it will enter test mode
Anyone seen this before?
It's really annoying for player 2 and the screen flips ( extra hard mode )
Brettster
1,276CR
I have checked them
All pins have continuity when on and not when off and nothing crossed
The in game test shows the switches on and off too when moved to on or off
Layer
376CR
Dessolder and replace the dips then. That'll let you know if the issue is due to the dips or from another corner associated on the board.
Before dessoldering anything, you should check and tell if your classic Irem to Jamma adapter is not faulty.Layer2015-10-17 20:17:30
