Luna lander pcb
bonehead
I'll get pix tonight
50 (100%)
1,729CR
Hi all, I just picked up a Luna lander pcb and wanted to know if I can test it in my asteroids upright?
Pin out looks the same for voltages but obviously controls are different.
Any idea's if it would be ok just to try it?
bonehead
50 (100%)
1,729CR
Ok thanks for letting me know.
Can I use the ar1 from the asteroids cab in my Luna lander cab to try it?
I haven't checked the ar1 in the LL and I know the mo it or is faulty but have a worker to try in it.
Need to get this pcb tested.
Equites
Chief Sheesher®
35 (100%)
3,329CR
My money is on the PCB not working (if it's the one on eBay).
Let me know if you want it refurbished.Equites2016-06-28 00:00:15
DanP
Administrator
2,232CR
Steve, probably best to disconnect the monitor when you first plug it in to test it. It's possible to blow a good vector monitor with a bad PCB. If you get signs of life measure the video voltages to make sure they are in the right range before plugging the monitor back in (turn cab off first of course).
Dan
bonehead
50 (100%)
1,729CR
Tested pcb tonight and no go!!! Just solid red led on control panel and spot killer.
Oh well the cab won't be fixed for a while yet then.
