MAME Cab setups
DanP
Administrator
2,232CR
Hi guys, I know 1 or 2 of you out there have MAME cabs. I myself have 2 (1 vertical 1 horizontal). Currently I'm running DOS, with ArcadeOS and MAME 0.36 as the PC's I'm using are old Pentium 3's. What are you guys using nowadays, I presume things have moved on. I like the DOS setup cos it's possible to power off the PC and cab all at once.
DanP
G
Guests
Guest
my last one was a winxp machine, that shelled on boot to game launcher.
prior to that it was good old gentoo with dzine and ades runmame
smythe
Amos Brearly
41CR
intsant sheller + tinyxp + maximus arcade (frontend)
usually use min p4 3ghz with min nvidia 64mb gfx and min of 512mb ram
usually runs rapid! allthough i dont use the chd roms!
smithers
Macro
2,009CR
still have two (horizontal and vertical), really need to sort out the vector mame cab sometime ...
Vertical runs mamewah (with about 50 games on), horizontal runs Mala (with about 80 games on) - vector will run no front end with 5 games on when it hits the top of the pile of things to do. Both use minimal install of XP and seem to survive me turning the cab off without shutting it down!
DanP
Administrator
2,232CR
Hey Macro, if you need any help with the VectorMame setup let me know. I could prolly sort out an image or something if you were really desperate. I got mine fully working with Ians menu and sorted the samples out with reasonable levels which took an age.
Did you know there was a beta of a new Windows version of VectorMame/ZVGTweak btw? Not had a chance to test it yet but I should do in the next week or so.
Does anyone know if it's possible to stop XP having any issues with hard power downs? Is it possible to stop it doing any disk IO, is there a special mode you can put it in?
Dan
trm
2,877CR
The only XP shutdown-resiliency options I can think of is it make sure that drive caching is as tight as possible. Open Device Manager and find your hard disks. Double click and then look at the Policies tab. There are a variety of options there about caching - disable as much as possible.
Then the next aspect is that powering off doesn't clear the "dirty disk" bit on the disks, so on restart you'll get the "Windows didn't shut down properly" screen with the safe mode options etc. It may be possible to disable the check for the dirty disk shutdown - I recall helping a friend who had a bug on Windows7 where it was reporting all shutdowns as dirty. Maybe google for something along the lines of "disable dirty disk check windows xp" or "disable dirty disk shutdown windows xp". There were some reghacks available to him but this was Win7.
I'll have a think to see if I can come up with anything better. I don't think your problem is going to be related to losing data (NTFS is a transactional file system, but you won't be writing anyway), it's going to be about stopping WinXP having a cow each time you power up. You may be able to set the timeout for the "Windows didn't shut down cleanly last time" screen so it defaults to something like 1 second and then boots as normal.
cheers
tim
ps Just had another thought - what about building a normal XP system then using something like Linux's grub as the bootloader - that may get around the WinXP check for dirty shutdowns. I'll have a thought exercise on this and see if I can come up with something useful.
pps Shame you're not using an old SCSI disk which had an actual write-protect jumper. They were very cool for doing naughty things on old Sun gear - no logs as the disk was physically blocked from writing ;)
ppps The above just reminded me - I don't know what the state of SDL Mame is, but if it's halfway decent you could go for a Linux system and just mount the filesystem read-only. That way you know you're not going to trash anything. I'm not 100% sure that you can have the / (root) partition as read-only, cos things like mtab need updating on boot, but you can probably emulate a live-cd style setup where your "write" disk is actually a ram disk so it doesn't matter that you lose it all with a dirty shutdown as the data never gets recorded. I'd have a look at building live-cd's
Macro
2,009CR
Dan
Cheers, I did have it working (once) in the Atari Asteroids cab, but then got a second bootleg Asty so decided to move it across to that instead, and revert the Atari back to normal.
just not got around to sorting out the Astorock yet!
WIll chuck you a PM when I get around to it.
