Marquee lights - replacements
neoretro
1,121CR
Hi All,
What’s the best way of replacing the old Fluorescent bulb marquee lights in the arcade machines.
Not sure where to start but I assume wiring something off of the power supply up to the marquee box.
I’d like to future proof some of the machines so would be great if it was LED or 15 fluorescent which are fairly common.
Dave
neoretro
1,121CR
Thanks Olly really appreciate that.
How would I connect them up? Take a 3 core chord off the main supply and connect it to the cable being sold with the light?
mathj
499CR
i seen them on ali express and wish for much less :)
the ones i got work straight from the mains,not tried them in a cab though
mathj2019-12-09 20:49:28
Sbdesign
SEGA collector
16 (100%)
1,724CR
220v - wire straight to the wires that are currently there. The led bars have a transformer in them. Its a doddle
Sbdesign2019-12-10 00:52:18
mozie
20 (100%)
530CR
+1 for these, installation takes literally 10 minutes, remove old tube/starter, screw in the retainer clips, push the t5 into the clips, splice into the power cable using desired method (they work with 110v or 240v) and job done probably forever.. ive had these in cabs for years and still going strong
muddymusic said:
TheDaddy
14 (93%)
7,230CR
neoretro
1,121CR
muddymusic said:
Thanks for the tips chaps.
Any idea which cable connects to what on these? No instructions.
LawmanAUT
80CR
Normally, there is an instruction on the light carton box.
I have such china led lamps too and if I remember correct, yellow is ground and the 2 others are the power lines. Mine are ready for voltage from 60 - 240 vac.
