paulcan69 said:Yes dude, all the mask roms are 100% compared to mame
The socket 11 chip/rom comes back as 98.3%
+ the wellon software flags up a red dot on one of the pins just as it goes to read it, and waits for me to click continue.
Whilst you're trying to get hold of a blank I'd investigate this. Have you tried cleaning up the leg in case it's got some galvanic corrosion or otherwise? Fine grit sandpaper will do.
Which pin is it reporting the error on?
Say the higher address line pin is corroded. So when the progger is stepping through each of the addresses to dump the byte at that address, it gets into the range where the highest address line is needed. But if that pin has a dodgy contact with the progger socket, when the Wellon thinks it's setting that pin high it's not actually getting through to the decoder in the ROM. So even though the Wellon thinks it's dumping the top addresses from the ROM, the high address line isn't being toggled so it's actually accessing addresses lower than the top of the IC. So most of the ROM dumps ok apart from those which need the duff pin to be set high. This'll show as an almost good dump but will have some differences as you've basically missed out part of the ROM.
Of course, if the flagged pin isn't an address pin then it's likely unrelated. Or if the red pin is a low address pin then it'd bugger up the dump almost from the beginning so you'd end up with less than a 98% match. I've not done the maths to figure out which pin could cause a 98% match so I could be barking up the wrong tree, but I've come across this before and it bit me in the arse
If you let us know which pin is being flagged then we can either rule this out or consider it as a possibility and figure out what would happen based on that pin being duff if we know what it is.
cheers
