Maximum Tune 3 Arcade Machine Errors
Hi,
I'm pretty new to owning arcades and have recently purchased 2x Wangan Midnight Maximum Tune 3 Arcade Machines. But I have have come across 2x errors, and I'm hoping for someone to be of help to what is what, or even better come and check them out in person.
The first error is that one of the machines doesn't select 1st, 3rd or 5th gear on the selector, but does select 2nd, 4th & 6th. When replaced with the gear selector that works fine on the other machine (both selectors work fine on the good machine), the same fault is produced. No code is displayed for this error.
The other machine that was fine has now produced an error code "E20" upon start up. Which from the handbook booklet I have refers to the feedback mechanism. I've switched the whole steering wheel and mechanism from the working machine to this one and the same error occurs. I've checked the connections on the harness and all is well, not breaks/corrosion etc. (so I'm thinking the board itself perhaps?)
Any light on this would be greatly appreciated, thanks.
derole
3CR
The first error is usually a bad microswitch but as you mention you switched the gear shifter already it would be worth checking the cable that goes from the FCA IO board to the shifter.
The E20 error is usually nothing to do with the steering wheel/motor but rather the force feedback board. This is located behind the rear panel underneath the monitor assembly. The board itself should look similar to the image below:
If you dont care about force feedback, most of the time you can bypass this error by going to the test menu, game options and then turning steering power off. May be worth checking connections/voltages before replacing the board incase its something simple.
derole2021-01-22 16:54:55
Hi Derole,
Thanks for your response, I'll check over what you've suggested and inform if fixed or not. I'm assuming that this is common at the same time?
Kind regards
jasonm737
270CR
E20 error fixed for someone by changing a fuse - 4th post on this link....
https://www.arcade-projects.com/threads/wangan-midnight-maximum-tune-2-force-feedback-help.7700/
I had issues with mine on first power up but it was just the cables had worked their way loose on the van. As you've just got it, I'd say reseat cables first, as a few of mine were not very tight and could easily shake out during transport.
jasonm7372021-01-22 18:44:25
