Mega touch help
Steve1978
2CR
Hi. I gave just bought a megatouch old quiz machine. It was sold with everything but it was in need of attention. After a quick play I can see first thing the psu for the board is dead, not a problem, I can fix that with a third party psu.
Secondly the OS seems dead, I get a hard drive boot failure. I have been in bios and the drive is there and available.
So here are my questions, if anyone can help it would be appreciated.
1 can I re-download the OS, if so how do I know which OS it should have?
2 can I reprogram the key with a later OS, this would / should give me better games more features
3 can I upgrade the mother board on this and use the board and key with a different board, or am I stuck with this very old celeron.
Many thanks, sure I will have more questions,
obcd
3,830CR
Just make sure you figure out the correct type of megatouch as the drives can't be exchanged between different models. What security dongle is it using? Is it a dallas key? If so, can you read the numbers that are printed on it. I have a megatouch xl extreme. That one was still using dos. It had an io board with a small boot flash disk and loaded it's program from a cd. I think they switched to linux afterwards. The firm no longer sells this sort of machines, but you might be able to find a working harddisk and dongle on ebay. I know there are cracked versions of the os as well that work without dongle. If you figure out how to clone the dongle, you could resell the harddrive afterwards. Check the datasheets of the dallas dongle. It uses a one wire communication protocol and will probably have some passkey protected memory regions.
