Megatouch Help Please
obcd
3,830CR
I think you read about the suicide chips used on earlier arcade hardware boards. Those where a form of copy protection. Modern pc mobo's usually have a CR2032 coin cell battery on the board to keep the real time clock and bios settings. You can measure it's voltage when the board is turned off. You should have at least 2.9V. It should not be a problem to replace that battery. In fact, I have seen the contrary. Boards refused to boot untill that battery "which was gone totally flat" got replaced.
Geoffers08
4CR
Hi Obcd,
I have just read the manual and my fears are right. A removed CMOS battery (or dead one), equals no boot on the board (as it wipes the "boot when AC power is restored" from the BIOS), however it seems shorting two points on the board, post battery replacement sorts this out.
Well Gents (Obcd and Dazzz), I have done a few more bits and have some updates...
This is DEFINITELY a Magatouch FORCE 2005.
I have tried a few more things (Youtube vids currently uploading), and I will report in the morrow...
Cheers for now....
Geoff.
obcd
3,830CR
I see what you mean. There is a setting in the bios what the pc should do after a power fail. It defaults to off. You have to short the pins where normally the power button would come on a normal pc, basically turning on the pc. After that, you have to set that bios setting again to switch on the pc after a power fail. It's really no reason not to replace that battery.
Geoffers08
4CR
Latest update.
Ok.. so last night I tried two more things... I tried to reset the BIOS manually, as per the instructions in the manual I got hold of, resetting to BOTH optimsed and fail safe.
Sadly, this had no effect whatsoever.
All went fine through boot (no mention of the audio hardware issue) - but same result, as far as loading the GUI, then "the screen controller is not responding.
So, moving onto, I tried a "DIP SWITCH 8" CMOS reset:
https://www.youtube.com/watch?v=A_ehUlmLC-M
Sadly, same result, all the way through to the GUI and then the now familiar "the screen controller is not responding".
I then tried to make sure the USB cable to the IO board was secure (a bit last ditch I know).
Sooo now I am stumped. This afternoon I am going to completely remove the MBO from the cab, and give it a good blast of compressed air and re-seat everything.
The one "positive" is that I do now now this is Megatouch Force 2005.
I have noted on E-bay there is a guy based in the US "Megatouch Guy" who repairs Megatouch MBO's, and also has compact flash based HDD's available (including the Force 2005). But to be honest I would rather get this sorted here in blighty (or at least Europe).
Geoffers08
4CR
Hi All,
well finally it is alive again!! :
https://www.youtube.com/watch?v=dNQ0yJD2yw8
It turned out that the HDD was somehow corrupt.
Dazzz did me a cracking deal on some spares, inclusive of a new HDD.... I tried this first and - whooo hooo! it works!
Thank you all so much for your help.
I am now going to do a full restore on this, and show it coming along in other areas of the forum as I go.
Cheers.
Geoffers.
