Picked up a nice Cub monitor at the weekend, a 1452 I believe but I may have that wrong from memory.
I got it to use with my Fluke but it should essentially be the same as arcade as my Fluke was previously running on a Polo 14" with no special trickery that I can remember.
So I've initially tried it on my Jamma rig and I can't get a picture that is anything other than very white and blown out. I think it worked reasonably for a few seconds before it went like it so pretty sure it's a fault rather than a bad setup.
What I've tried:
Where do I go from here? Any ideas?
Before anyone says "cap kit", I don't believe in them, but I'm happy if anyone can recommended any particular caps that could impact the black level. To be honest, I'm struggling to spot any on the schematics.
What I've tried:
- Ensured that the TTL / Analog jumpers are set to Analog. In this mode, the contrast control on the front has no effect.
- Start by turn all R/G/B black level controls fully off. This gives a good colour but it's heavily if not totally blue screen. Tells me the guns are good though!
- Performed a black level setup procedure on the monitor, so with HV (VR4), brightness and A1 (grid) all at minimum I have set the BL for R/G/B to 140V each as per the manual. By now we are back up to very white.
- Removed and verified that both the brightness pot and the contrast pots are good and any connectors are making good connections (contrast is a remote control).
