Mini Oscilloscope
Jon-A-Tron
330CR
I received this in the post yesterday. Ordered from banggood around Christmas time and delivery was about 3 weeks.
JYETech DSO Shell. ~£14 delivered.
Comes as a partly assembled kit. You need to solder on various resitors, capacitors, pins and headers before finally testing, calibrating and assembling.
There is a slightly more expensive pre-made unit but i thought i'd give this a go.
Resistors measured and divided.
Main board and analogue board populated and soldered.
Final assembly. Tested and working.
Plan to put a mobile phone style battery and usb charging circuit inside the unit to make it portable. Just running of a 9v battery at moment.
Pretty neat little device for £14.
I know this does not have the functionality and precision of a proper full size scope but i dont have a proper scope and they are expensive. This is not. For what i need it for it'll do for now.
Now if only i can get MAME on it....
Infact that dial would be great for Tempest...hahaha.JonTron2018-01-23 10:06:39
Brettster
1,276CR
That's really cool
but are the specs of it any use for PCB repair or general scoping of things?
I dont have a scope myself but this does look interesting
Jon-A-Tron
330CR
Since i built it i havent had a chance to sit down and really test it out. It has pretty good range on the dial and the test generator 1khz signal could be used to check ic functions.
Im only expecting £14 worth of oscilloscope. Anything more is gravy.
robotech
823CR
looks good for £14 I would also be interested if its any use for pcb repair / fault finding
could be a good way of learning to use a scope without spending much
and the kit looks fun to build
Stickman
355CR
I grabbed one of these, but yet to assemble, I was looking to try it out as a enhancement to just a logic probe until I get a full blown scope. For the price it has to be worth a punt.
Jon-A-Tron
330CR
Yes i wanted something that would show me a little more than a logic probe would.
It is sattisfying to put together as its not too difficult. You can get a version there you have to solder all the tiny surface mount components too if you want to practice doing that.
The one i got took about hour and half to fully assemble.
Also, there are loads of these on ebay. The company that make them only sell them on banggood and are trying to close down all the copies from ebay. Dont know what the difference, if any, between the versions are but if you want to get it from the official source then get from banggood.JonTron2018-02-02 08:25:49
Stickman
355CR
I went with eBay, looks exactly the same as yours, opted for the surface mounts already soldered. Not phased by this sort of stuff, do the same for guitar pedals and also chassi repairs. But it is always fun to build something and then make use of it.
