Missing Key / Lock Picking
tinman
14CR
My lock picking is awful, and I don't have access inside the monitor section of a cab without the key. Don't mind replacing the lock, it's just getting in there!
Anyone have any tips?
Fantazia2
2,246CR
Depending on the cab there may be other ways to get access.
On some Jamma cabs if you can open the coin door and unlatch the control panel you can then usually remove the glass bezel and get access to remove the monitor out of the front, you might need another set of hands to unplug the video and power to the monitor, then you may be able to access the rear of the lock to remove it as well, if thes the lock on the back door youre having issues with.
patloz
844CR
If it s a cylinder lock its worth investing in a Southord cylinder lock pick, they pick the lock in a matter of seconds with no skill and you can get a key cut from the settings on the pick if you wanted to keep the lock barrel.
Driling locks is a messy job and can be harder than it looks some times.
