Mistercade Video Sync Issue
jerryspaghetti
38 (100%)
1,998CR
Got a Mistercade setup with the Mister FPGA. Came fully assembled with a 128gb card which can’t fit all the stuff I want so bought a 400gb card.
Went through the process of setting it up with mr fusion and when I plug it back into the Mister the video won’t sync. I’m getting a vertically scrolling image. The hardware is fine as it still works with my 128gb card but has anyone else come across this odd issue?
Also I’ve tried this in my Jamma cab and on my supergun and same problem so the sync issue is coming from the mistercade/mister set up itself.
For clarity I’m following the video below to perform the set up.
https://youtu.be/kHgT2scNfn4jerryspaghetti2023-01-16 00:29:36
RossRoss
81CR
Yeah, what Eccentric said:
Problem: Cabinet monitor display is rolling, distorted or scrambled.
Solution 1: Make sure you’ve copied over the appropriate 15khz or 31khz MiSTer.ini file from the MiSTercade GitHub to the root of the SD card “MiSTer.ini”
See the “Configuring MiSTer Controls, Video and Audio Output” section for further details.
Solution 2: You may need to change the CSYNC jumper.
Solution 3: Open up the MiSTer.ini file and confirm that line 3 has the scan doubler set to 0, and line 5 has composite sync set to 1:
forced_scandoubler=0 ; set to 1 to run scandoubler on VGA output always (depends on core).
composite_sync=1 ; set to 1 for composite sync on HSync signal of VGA output.
jerryspaghetti
38 (100%)
1,998CR
Cheers guys, I managed to get it sorted by just copying the config/Linux etc from my 128gb card.
One issue I am having (and had with the 128gb card) is that I can’t rotate the screen. Just does nothing when o select it.
Is there something obvious I can change in settings?
thegreathopper
1,253CR
The screen doesn’t rotate, the Mister emulates hardware so unless it’s in the original game it won’t rotate.
pooman2084
Be Attitude For Gains!
26 (100%)
1,886CR
I think Mister does rotate in HDMI mode, not for JAMMA though.
You can rotate the menu screen for easier navigation through the menus if you are playing vertical games on a vertical monitor. It’s an ini option.
