Caveat
The usual caveat from me.
I do not feel entitled to, nor do I expect, your time, energy, knowledge, and attention.
I am often slow to respond, as I am not a typical modern day person that has a mobile / cell phone, plus I work SUPER slow on personal projects. 🥱
Either way my gratitude for any advice is huge 🙏 ... so ... thanks just for even this bit! 😅
Current Situation
Hiya ... just starting this thread because I know I'll need to ... hasn't even been dispatched, yet, any images that follow are the sellers (at the moment) but hopefully I'll have better, later.I just got this from an auction and will need to repair the rendering issues. Hoping this can be done simply by replacing / reflashing some chips or something ... I really dunno, but I'm sure I'll get there, one day.
Even more ideal would be that a broken trace, or component, somewhere, has closed off that part of the board and a good cap/resistor refresh (which wouldn't hurt anyway) can save it ... but I doubt that's the case.
Haven't done a jot of research on this, yet ... but I will.
Just getting the thread up and running for when that all happens.
E
Original eBay Description
!! FOR SPARES OR REPAIR ONLY !!
For sale is a set of Sega Model 1 Virtua Racing arcade boards, wiring harness, power supply, steering wheel and pedals on a 75cm x 50cm chipboard backing sheet.
Has been stored away in a cupboard for about 2 years since I last played it, when it was still working fine. Sadly, now it has missing polygon rendering making the game unplayable. Service menus, controls, gameplay and sound all work correctly, just no polygons. This is a common fault with the graphics board apparently. Decided to sell it on, hopefully to a collector of other Sega Model 1 hardware, maybe you have a working graphics board to put in this one to fix it, or can source one.
Video output is 24KHz medium resolution. It will not work on a standard arcade monitor, TV or VGA monitor on its own. I use a CGA/EGA to VGA converter for this and my other Model 1 boards, used here to show the game running. It is not included, nor is my VGA monitor or speakers. You can buy one of these video converters for about £25 though.
The steering wheel and pedals are a modified Logitech set. There is no force feedback or wheel centering (just needs some springs fitted inside iirc). Two big red buttons on top are Coin & Start. On the rear of the wheel are Up-shift/Down-shift and the four small buttons on the wheel are the four coloured VR buttons controlling view. The pedals connect to the rear of the steering wheel via DB9 and the wheel then connects via DB15 to the I/O board.
Stereo audio output is a pair of RCAs, line-level, with sfx and music mixed together via a mixer board.
A short video cable with RGB, sync and ground is also supplied.
Due to the fragility, size and sheer weight of everything, I would prefer local collection from the Morpeth area, just north of Newcastle upon Tyne. I will show you it running and once you're happy to go I will need to scan the QR code that ebay will provide you before handing everything over.
If you can't collect it I can ship it using ParcelForce but the boards would be sent minus the chipboard backing they're attached to currently as it is too big to go in any box I can get my hands on. Each board would be packaged up inside its own anti-static bag for protection and then wrapped extensively in bubble wrap and placed in a strong box for shipping. I've guessed at postage size and weight as I don't want to remove everything from the backer board unless I have to. Any excess postage will be refunded ofc.
What you get:
Virtua Racing board stack, consisting of:
834-8941 memory board with Virtua Racing EPR-A14878 / EPR-A14879 / EPR-14883 / EPR-14882 EPROMs.
833-8940 (837-8935) CPU board (serial# 930224.2508E).
837-7894 Graphics board (polygon rendering completely missing).
Link play board (unable to see the number on it). No idea if this works as I don't have another.
837-8936-91 I/O board with 14869B EPROM.
837-8679 (837-8939) Sound board with EPR-A14870 EPROM and 837-8680 Sound option board, plus stereo mixer board and RCA cable.
Wiring harness connecting everything up.
Arcade power supply with UK 3-pin plug and 3D-printed enclosure.
Steering wheel and pedals.
If you have any questions or would like to see anything in greater detail, please message me and I will try to accomodate requests. Thanks!
Original eBay Images
The original eBay images will be thumbnails in the below spoiler, 10 of which are attached to this post.Edited to add - I did not take the steering wheel, as no-one took my one in the freebies section, I'll be working with that.
