monitor dischage question
cosine
14 (100%)
595CR
Hiya,
I'm about to discharge the monitor in my Konami GT cab to send the chassis off for repair, when I discovered this wire lurking in amongst the other wires connected to the neck card:
Looks like a broken pin is stuck in there, and the wire leads to here:
I'm assuming it's a ground wire, so am I still safe to discharge the tube, as I'm fully aware/paranoid of the amount of volts CRT tubes pack? While I'm clutching at straws, would this explain why the screens rolls vertically after a while?
Cheers.
Brettster
1,276CR
That looks like the Ground wire that should be connected to the neck board!
not 100% sure if that would cause your issues but it sure wouldnt help!
cosine
14 (100%)
595CR
Yeah, I've since found where the pin used to be
No idea how long it's been like that, I've never touched the neckboard since getting the cab a couple of years ago.
Brettster
1,276CR
worth discharging the monitor and removing the neck board and reconnecting it, could sort out your issues.
just connect the lead to any other grounded metal part, Every time I've discharged a monitor it's been very anti climatic, barely a pop if anything at all
gunblade
9,144CR
yes it could cause all sorts of odd issues- on some monitors the secondary power supply will fry
use a spare header pin from the chassis, there should be a couple
cosine
14 (100%)
595CR
After a rather anti-climatic chassis removal, there was no spare header pins that I could see to replace the broken one, so I've ordered some, hopefully will be here in a few days.
