Monitor help please
Silvercity
26CR
IMG_2623.jpegIMG_2622.jpegIMG_2621.jpegIMG_2620.jpegIMG_2618.jpegIMG_2619.jpegGood evening, could anyone give me some things to try to get the colours to combine? When I twiddle the little knobs on the neck board the colours change but are just one colour at a time. Any help much appreciated. Complete novice. Super happy to even have a picture on the screen 😊
Update: screen just turned off after 30 minutes play. Will try turn on in the morning.
thegreathopper
1,248CR
I would start off by removing that JNX adaptor, you shouldn’t need that with a 1 slot on a jamma cab.
Its also really weird the game plugged in is Super sidekicks and the game playing looks to be KOF 1997.
Silvercity
26CR
Thank you. The cabinet used to have a multistot and i was under the impression the jnx stops you burning out something to do with mono and stereo sound? I will try without, as it can't hurt for a little while?
Yes, I was playing KOF 98 but then i tried super sidekicks just to see how it looks.
Any other advice Chassis related?
big10p
Coins detected in pocket!
6,071CR
The pots on the neck board are to adjust individual RGB cut-off and gain. They'll need recalibrating. What was the picture like before you started twiddling the pots?
thegreathopper
1,248CR
Oh yes if it had a 4 slot you will need that adapter or move 1 wire on the harness but that may be for the future.
I would press the test button on the Neo Geo and see what your RGB and white look like.
Silvercity
26CR
Thank you, the screen has appeared to be dead since I bought the cab, no neck glow. Then last night I wiggled the neck board and the screen came on in green. So I twisted the pots and from they I could change the colour one at a time. I then had it running for about half an hour and when I was playing the game (in blue) the screen appeared to quickly collapse with a horizontal white line that quickly disappeared and now no screen or neck glow again.
big10p
6,071CR
I would make sure the neck board is fully pushed onto the tube, and that the remote board is connected securely. Do this with the monitor off. If no luck with this, the chassis probably needs servicing.
Silvercity
26CR
Yes will do. Any components that are more likely to be related. Was thinking of checking the parts on the neck board. Any chance of a crash course 😉 how to check the 3 legged thingies? Thanks again
big10p
6,071CR
Not really as all colours look like they're working. There is another pot on the neck board that has the plastic adjuster missing in your pic.
gunblade
9,084CR
ok so you see you have 200v video b+ and you have cut offs, whats missing is parts of the video signal - all very odd
only time i have seen that fault on polo is the 1r5 resistor
out of interest if you remove that jamma adapter does it make any difference, have you tried a different game board?
do contrast and brightness pots work on remote board?
otherwise could be an issue on the lm1203n ic on the neck card
