neogeojames
- Credits
- 41CR
Please help, I'm trying to connect normal positive video signal to a nintendo negative colour monitor.
Looking online,I found a guide on mike's arcade. So I brought the components needed and opened the chassis.
Instructions were:
To convert the Sanyo monitor to accept normal, positive video:
1. Remove the wire jumpers that have been installed in place of
transistors TR201, TR202, TR203.
2. Remove R213, R214, R215.
3. Install the following components:
a. R201, R202, R203100K
b. R210, R211, R212100K
c. R213, R214, R215820 ohm
d. R217, R218, R219560 ohm
e. TR201, TR202, TR2032SC1815 or equiv.
f. C202220uf 16V
g. D2101N40
So looking at step 1, I was more than a bit confused when there were transistors in place of where the jumpers supposedly are!
There's already the capacitor mentioned inC202
Resistor R201 is way at the back of the board nowhere near the RGB section.
And the diode is silkscreened in two places, one with a wire attached. Do I put both in?
I scratched my head and realised the instructions are for the 20 inch screen not the 14 inch screen, however these are supposedly the same chassis apart from some larger value caps on the 20 inch version.
Please help. I'm really trying hard to revive this machine and keep hitting hurdle after hurdle
Instructions were:
f. C202220uf 16V
g. D2101N40
