Monitor help
g60hot
53CR
Hello all i have a Hantarex 25" monitor which although has zero screen burn is showing slight probs and wondering if any one can help. So here is what she is doing, when first turned on its a bit blurry, once warm after about ten mins picture seems nice and bright, however in the left hand corner of the screen it has a funny colour issue, looks green, the screen also has a very faint wobble to it also, which is getting on my nerves.
Let me know what you think
Equites
Chief Sheesher®
35 (100%)
3,329CR
The corner problem sounds like just a de-gauss problem. A wand may fix that, or maybe something on the corner location is having an influence on it (i.e. transformer).
RaveN
1,325CR
The colour issues is either because a) Your degauss circuit isn't working, or b) It is working, but part of the chassis is magnetised which means (as Equites says) you could try a wand.
I'm not particularly knowledgeable with monitors, but a flicker/wobble can be caused by quite a few things, like caps, horizontal/vertical position pots (depending on what direction it wobbles in), and the 50hz hum wobble caused by the power section. I'm sure there's many other causes as well, maybe a video will help people track down the issue.
