Gunblade above is a very reputable service engineer when it comes to monitors tho to show no bias there are other brands and members on here WHO WILL ALL gladly (i believe) help and advise you
FIRST THING IS THINK SAFETY electricity can not be seen but easily felt SEE THE STICKys AS ALREADY wisely mentioned above (discharging)
monitors work on a few different voltages you can normally tell if they are fre-voltage 240volts ac if they have 3 wires including an earth......... monitors with 2 wires are often fed in the region of 100 - 130volts ac and do need a step down or isolating transformer as they can not be powered direct from a mains supply ............... find out what you can from labelling on the rear or from repair topics similar ON HERE........ many chassis are printed with the input voltage on the layout printing near the power input ( Note some of these still need some mains input to on the chassis to power the degaussing of the tube and will be fed with a 4 wired supply plug 2 seperate voltages)
you should not require a video signal generator but a good set of insulated screwdrivers and a miultimeter will definitely be of benefit .......and some soldering iron skills ? may be needed.........
and dont let the rest of the family join you while its opened up on the lounge floor as they will know less than you do OUCH
We all have to learn with this hobby (and all began somewhere once upon a time) which i turned into a business in the late 70s and believe me its tough to get to grips with many necessary repairs even fuses and wiring a plug is beyond the everyday knowledge of some collector hobbyists ( i have just been helping advise you on a lock you did not know if it turned clockwise or anticlockwise) we are all nice people on here ......... tho i get little time even tho i am basically now retired and further retired/restricted due to lockdown which prevents me going any distance and my still working business is 60 miles from home
and i met technology as it came in ......... VALVE AMPS ON JUKEBOXES was my hobby and restoring them as i was a farm manager back then LOADS OF EMPTY SHEDS and EVENING WHEN I HAD TO BE ROUND but others did much of the driving and and work in the fields ( tho i and my wife drove combined harvesters for 10 hours a day 7 days a week in summer .... so my hobby took me back to the 60s when i had a flirting with PENNY Allwin FLICK BALLS and e/m PINBALLS at rhyl fair as a schoolboy ( my older sister was even a bingo caller for Seldons at Rhyl where my grandmother lived )
and ALSO pinballs i had about 10 or more most got restored with relays and contacts ........... NO ELECRONIC circuits by 1983 i was fully involved in amusements learning the "NEW" stuff as i had by this time owned several electric controlled jukes and several (about 40 - 50 space invaders asteroids and even began to invest in COLOUR MONITOR VIDEO GAME MACHINES ////////////// theres a lot like me on here
just a pity many live distant to each other ? MY THEORY WAS IF SOMEONE INVENTED IT years earlier WITHOUT HELP JUST KNOWHOW ? THEN by THE 80s with books and manuals and plenty of people about who were self taught repairs "should be easy" NO NO NO but they were tackle-able with patience and understanding .....and i had a few shocks along the way in the early days so know how it is !!! and spent some college time getting the qualifications ........ tho i could use a meter and solder real well before that and got distinctions at most exams ( BUT IT DOES NOT HELP AT ALL IF YOU DONT KNOW WHAT YOU ARE PLAYING WITH .... ) i now meet surface mounted miniture ics and dont really have a clue //////// BUT I ADMIT IT and know my limits ............ ASKING HERE IS YOUR BEST FIRST MOVE and hopefully someone like me but sadly not me. WILL HELP
meanwhile... sat here i can advise on ukvac and believe me i have seen some VERY DANGEROUS SITUATIONS when visiting members homes to help out ,
no criticism of anyone wanting to try it themselves as it does cost to get the 'experts' in AND i have asked plenty questions myself of people more knowledgeable than me and i have a HNC and city and guilds level 3 digital and TV and radio YET I STILL HAVE GRANT DO THE ODD SERVICE (gunblade)
its not the ability now as often the availability of parts and regularly having to replace more than one part
i once wrote a long tutorial just on working with a multi-meter as i went to a guys house who had a load of cabs and wires hanging out of plugs on some of them
YOU SAY YOU HAVE VIRTUALLY NO RESPONSE from the machine
check all the visible things first without power on make sure the wires are even tight and correct in the plug .................... i on a couple of occasions rewired a loosely wired blue negative terminal on one it had nearly burned away
then on power supplies loosely soldered components cause no end of issues and many psu's are actually cheaper to replace than repair AGAIN 'no user replaceable parts' can be obtained in many case
i am not getting into your particular case here but just advising on the perils and THINK SAFE and start at the beginning basics ................. power at source / on off switches / monitor isolating switches (when doors are opened) / then BEFORE GOING MUCH FUTHER GET A CHEAP IF NECESSARY MULTI METER FROM EBAY or ELECTRICAL STORE not too basic but should be a few around the £20 - £30 range do a lot of functions including transistor test etc... but must do voltage AC and DC resistance and continuity as they all basically do these things
READ THE TECHNICAL REPAIR STICKYs ON HERE SEE WHAT OTHER GOOD TECH KNOWLEDGE MEMBERS RECOMMEND ................... especially topics which ask "WHAT TOOL DO YOU RECOMMEND ?" good luck
there more pleasure in this hobby if you do your own restorations but when you are able to buy the expensive stuff it usually works anyway ,,,,,,,,,,,, BUT WHEN IT LETS YOU DOWN ??????? and it can !!!
69er2021-02-01 14:23:20
