monitor SMPS issue,
monsterman
3CR
Hey chaps, i've got the aforementioned problem with my Makvision 3M25 (multisync)
I'm manged to get a mate with a scope to probe a few components around the SMPS( as I suspect that this is the cause), I've replaced the HOT, filter cap, vertical IC
I'm getting about 160v after the bridge rectifier, but then its all goes to sh*t
The monior its tweeting about once / second
I'm getting about 1v on the B+, spiking to 10v (every sec)
PWM (3842) pin 6 I'm getting 4 pulses per second 70 micro secs apart
PWM (3842) pin 4 sawtooth 3 pulses per sec 3v high
PWM (3842) pin 7 jumping every second from ~10 v - ~17v
Diode d1 (see vid Makvsion 2)
Pin 1 (TLP621) optisolator, getting 1v / pulse, should be 12v
https://na.suzohapp.com/pdf/service_pdfs/makvision/makvision49-3056-00_schematic.pdf
https://www.youtube.com/watch?v=BWwbySWp1w4 (TPp61 I think!!)
https://www.youtube.com/watch?v=wbOBU9UhAek (diode D1)
https://www.youtube.com/watch?v=NKgYFqMIbJA (pin 7 PWM I think!!)
1st+3rd you tube vids above might be the other way around
Below is pin 4 (PWM)
Can anyone give me any clues as to what I should probe next to diagnose this fault.
I'm not that good at all with electronics, my mate in work though is, but he just doesn't know CRT's
thanks for taking a look at my post and other info would also be gratfully recieved.
Dave
obcd
3,830CR
It could be a short on the B+ voltage. I usually test such with the HOT removed and a 25W - 40W light bulb as load on the B+ voltage. (If there is a short on the B+, it's often the HOT or LOPT that are causing it. Basically, removing the HOT disables the horizontal circuit.
monsterman
3CR
thanks so much for the response, I will give it a try, there's a B+ point on the board and obviously a few grounds dotted around, I take it I run connections from these to a bulb, would that be right?
Dave
obcd
3,830CR
Yes, that's correct. It's best to have some load on such a smps. Without load, some refuse to run properly. It's also possible it has the correct output voltage without a load, but not when there is one.
