Hi guys!! Have a problem with my b/w monitor. I replaced all caps and after i plug it in the screen was fine, but as as started to do some adjustments, vertical sync and hold, the screen suddenly collapsed. So now i got so called vertical collapse. All forums and e.t.c is suggesting to change the vertical deflection IC. But in my case i know thats NOT a solution, because i have 2 identical monitors, and i can interchange parts. So i pulled the IC from other chassie, and same result. Pull IC from non working to other and it WORKS. So its definately NOT vertical IC. So any thougts what coud it be? I have resoldered board for cold solder joints, replaced all electrolitic caps so far. Still the same vertical collapse. Please any advice?
