brown/blue 197. then straight to 1, nothing at all on black white ? is the isolation transformer trashed ? switching power supply ok for the boards all voltages in line with what should be expected .
I'm guessing by the look of the connector it's either an MTC 9000 (or similar Hantarex model) or a Kortek KTN variant, in which case as said above two pairs of wires are AC 120v for the monitor power and AC 240v for the degauss circuit.
Trace both sets of wires back to source. The circa 200V might just be tapped off the input to the isolation transformer. The missing 120V will be (should be) an output from the isolation. Either way - just trace the wiring back and see whats what. Is there a fuse protecting the input / output from isolation? Check that/those.
